Hi Guys,
One WT Part with CAD is assciated each other if i change the attributes in WT Part not updated in CAD. How we can over come this issue. [First time which i enter that value and attributes came in CAD, but only thing edit in WT part is not updated in CAD]
AJ
You have to use a function "Publish to CAD" for propagating the attribute change to CAD from the WTPart
CS272669 - How does Publish to CAD action work
PetrH
Hi @HelesicPetr thanks for the replay
CAD software is AutoCAD
Step 1 check out the WT Part modified and then check in to Windchill.
Step 2 Use the Publish to CAD option to publish
Step 3 You mean it'll updated in the AutoCAD file. [It's not updated on my case]
Aj
Maybe it does not work for AutoCAD. ask PTC support.
PS> PublishToCAD propagates information from WTPart to CAD Document and then
Workgroup manager does the propagation to the model.
PetrH
This is not a customization question, rather CAD interaction/integration.
The type of association between Part and CAD controls the synchronization. Also there is a topic called Attributes mapping between part and cad.
How are you changing the attribute on part? Are you using the collector?
