Version: Windchill 12.1
Use Case: Using a BAC in a CCD to update document templates, workflows, enumerations, attributes, and type.
Description:
Is anyone else having BAC Conflict Errors when loading a CCD package with a BAC? I'm testing the CCD on a dev server with updates to document templates, workflows, enumerations, attributes, and types. The first error I receive is BAC_DOCTEMPLATE_WITH_SAME_NUMBER_EXISTS. The BAC default conflict resolution is OVERWRITE and the service.properties file was changed to use the BACConflictResolver for BAC_DOCTEMPLATE_WITH_SAME_NUMBER_EXISTS. However, we still receive the conflict error. If I remove all the document templates from the BAC, I then receive ENUM_DEF_WITH_SAME_IDENTITY_EXISTS, ORGANIZER_WITH_SAME_IDENTITY_EXISTS, BAC_TABLE_VIEW_EXISTS, TYPE_WITH_SAME_IDENTITY_EXISTS, and WORKFLOW_WITH_SAME_IDENTITY_EXISTS errors. Within the UI, overwrite isn't an option in the event monitor for conflict resolution.
From "Help Center" - "Document Template Conflicts": https://support.ptc.com/help/windchill/plus/r12.0.2.0/en/index.html#page/Windchill_Help_Center/BACPImportConflict.html
Hi @DP_12924145,
Anurag
