Can't load Delegate task to Cognos.
shindemayur
I have created a file /opt/ptc/Windchill_11.0/Windchill/tasks/ext/re/report/SB_Report/SB_SubjectReport.xml
then, created Delegate,
Repository Type :com.ptc.windchill
Type Identifier : com.ptc.windchill.enterprise.report.ReportTask
Source URL :/ext/re/report/SB_Report/SB_SubjectReport.xml
Description :Report Task Example to show number of document.
executed commands from windchill shell,
java com.ptc.windchill.enterprise.report.ReportHelper updatemodel              and
windchill com.ptc.windchill.enterprise.report.ReportHelper modelupdate
Restarted Cognos.
Still can't find Data Source in cognos  under "com.ptc.windchill.enterprise.report.ReportTask"
What is missing ?
Also I can get output seen if I executed  file from browser using url
http://devapp2.organization.com/Windchill/servlet/IE/tasks/ext/re/report/SB_Report/SB_SubjectReport.xml
Output:-
<wc:COLLECTION xmlns:wc="http://www.ptc.com/infoengine/1.0">
<Unknown-Class-Name NAME="saReportData" TYPE="Object" STATUS="0">
<wc:INSTANCE>
<SBNumber>SB001</SBNumber>
</wc:INSTANCE>
</Unknown-Class-Name>
</wc:COLLECTION>
Initially I just want to pass a hardcored value. I already have some custom delegated , which are working fine.
XML File  Data
<%@page language="java" session="false" access="http|soap"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<%@page import="java.util.*"%>
<%@page import="com.infoengine.object.factory.Group"%>
<%@page import="com.infoengine.object.factory.Att"%>
<%@page import="com.infoengine.object.factory.Element"%>
<!--com.infoengine.delegate.def
@delegateName SB_SBNumber
@typeId com.ptc.windchill.enterprise.report.ReportTask
@installDelegate true
<!--com.infoengine.soap.rpc.def
@return INFOENGINE_GROUP ${saReportData} {columns: java.lang.String SBNumber}
<ie:webject name="Create-Group" type="GRP">
 <ie:param name="GROUP_OUT" data="saReportData" />
</ie:webject>
Group saReportData = getGroup("saReportData");
String number = "SB001";
Element maDocumentElem = new Element();
Att maDocumentAtt = new Att("SBNumber");
String maNumber=number;
maDocumentAtt.setValue(maNumber);
maDocumentElem.setAtt(maDocumentAtt);
saReportData.addElement(maDocumentElem);
<ie:webject name="Return-Groups" type="GRP">
 <ie:param name="Group_in" data="saReportData"/>
</ie:webject>
0 REPLIES 0
