Customer Question
We are into our first week of using the new Windchill system, and so far we are liking it. However, I do have one question for you. Previously, in Intralink 3.4, we were able to locate a specific check in form, and delete it along with the part iterations introduced, effectively undoing the check-in.
So far I have not found a way to do this using Windchill. I would like to be able to find a specific check-in, see what parts were modified, and delete the latest iteration of those parts.
There is no check-in form to worry about. Depending upon access control and database integrity considerations, you can simple select delete from the Actions of the object page (or right mouse from a table view).
Note that individual iterations can often be deleted, but all versions will often not work because of integrity violations.
