Connecting Windchill to NATS messaging queue
Dobi
Version: Windchill 13.0
Use Case: We're planning to use NATS for the messaging queue between Windchill and other systems. When going to test the connection via java code, Windchill throws the following: SEVERE: exceptionOccurred, Connection: 37, Exception: java.util.concurrent.ExecutionException: java.io.IOException: SSL required by server.
Description:
We're connecting Windchill to upstream and downstream systems by way of NATS as the messaging queue. I have the NATS .jar and dependencies in Windchill, code written and compiled successfully.
I run a simple example to connect and post a sample message straight out of this NATS functional example. Windchill throws this:
Feb 07, 2025 5:29:05 PM io.nats.client.impl.ErrorListenerLoggerImpl exceptionOccurred
Is this a certificate issue (i.e. need to add a certificate for NATS to Windchill?) or are there some other settings (securityContext.properties??) I'm missing?
Dobi
(To:VladimirN)
CS166338 was my first inclination too. It turned out that the default url for NATS is "nats://xxx". When I replaced that with "tls://" the rest of the connection and .creds file worked just fine.
2 REPLIES 2
VladimirN
(To:Dobi)
Helpful article - "How to configure Windchill to use the https protocol with SSL encryption and (self-signed) certificates in an environment with replica servers in Windchill": https://www.ptc.com/en/support/article/CS166338
Dobi
(To:VladimirN)
