Create substitute using WRS endpoint url
Vedamurthy
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.1
How to create substitute for a component in BOM using OOTB ODATA Windchill Rest Services
Here are the errors that I faced
Not applicable
4 REPLIES 4
Hello Vedamurthy,
Is is possible to share the full error log file?
KR,
Charles.
Hi cgautier,
There is no error.
I want to know if there is any WRS endpoint available to create a substitute.
In PTC documentation I did not find any.
HelesicPetr
(To:Vedamurthy)
Hi @Vedamurthy
Have you check the WRS Documentation in Windchill?
If no, check it.
I don't believe that the substitute creation exists in  the WRS endpoint. I've never seen it there.
As @tarik_p mentioned the Article - CS365619., The endpoint function really does not exists.
So you have just one option. Create own custom WRS function to do so.
PetrH
