I am looking for any information on how to enable a dark mode for my in creo Windchill. Last Ive checked it is not an option and I would love it to be. I was able to make my outside browser Windchill dark.
Hi @JG_10788594
The UI configuration does not exists.
If you want to change the color schema of the system, change all CSS styles in the system..
Windchill Help Center - Customizing the Theme
PetrH
Are you looking for a way to change the color theme for the embedded browser in Creo Parametric? If yes, this might be a better question in the Creo Community. Personally, I have never attempted to change this.
@JG_10788594 You can customize the css styles as suggested by @HelesicPetr , if you change correctly the text and background colors this would be a good solution.
In addition, there is a hack in modern browsers to enable dark theme, see https://www.ptc.com/en/support/article/cs371620, but looks not very promising. It was not tested on the embedded browser in Creo, only in the standalone browser.
+ In Windchill 13.0.1 a new theme has been introduced with a new font-size and colors with more accessibility features, it’s called PTC Design System. You’re going to like it, certainly !
+ Generic UI customization articles are collected in this hub https://www.ptc.com/en/support/article/CS361437, and accessibility features in https://www.ptc.com/en/support/article/CS352883.
Hi @JG_10788594,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
