Hello Community,
I wanted few diagrams or pictures that represents the below links in Windchill. If any of you has anything on the same, requesting you to share it.
Link Objects: WTPartReferenceLink, WTPartDescribeLink, EquivalenceLink, Owner, Calculated, Image, WTPartAlternateLink, PartSubstituteLink
Thanks.
you can use , query builder to create a nice diagram :
1- dd the link object table
2- look for the classes for roleA and RoleB objects
3- add tables for class A and class B objects
4- link the tables
5- validate links
This is an HUB article on Windchill data model
https://www.ptc.com/en/support/article/CS137012
4- link the tables
5- validate links
