EPMDocument file size difference noticed
NP_10570407
please find attached the image.
We manually downloaded a Creo file(associated with EPMDocument)  and also tried file download through script. there is a difference between both the files size.
1. why there is a difference between files?
2. files downloaded through script are not opening in creo due to file size difference. how to resolve the issue?
HelesicPetr
(To:NP_10570407)
Hi @NP_10570407
The problem is that the file is not stored correctly by your script.
Without knowing the source code no one can help you.
PetrH
HelesicPetr
(To:NP_10570407)
Hi @NP_10570407
PetrH
Thanks a lot for the reply HelesicPetr,
I agree with your point. We have modified the script and re-executed. Now the issue is resolved.
Thanks again
