Is it possible to configure email notification sent from Windchill to email accounts of Office 365, inside our organization? I have been told that it is not possible, but I can believe it.
Yes it is, and there is an article for this.
Search on the kb, and you'll find what you search.
There is a small thing to be aware of, the permission to send on behalf on someone else or set Windchill to send email always with the same.
I have search in the kb, apparently it is not possible
It is possible and it works: CS288408
As I early wrote, make sure the account you're using is able to send "on behalf", otherwise configure Windchill to send notification from the same email address as described in CS10334
