Error rehost utility rename scenario
dfante
Hi All,
Today I tried to rename the rehost utility in a windchill 10.2. After launching the bat and after configuring the file rehost.propeties I return the following error:
BUILD FAILED
C:\ptc\conf\rehost.xml:103: com.ptc.wc.rehost.exception.RehostException: java.sql.SQLRecoverableException: IO Error: The Network Adapter could not establish the connection
Nested exception is: java.sql.SQLRecoverableException: IO Error: The Network Adapter could not establish the connection
    at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:489)
    at oracle.jdbc.driver.PhysicalConnection.<init>(PhysicalConnection.java:553)
    at oracle.jdbc.driver.T4CConnection.<init>(T4CConnection.java:254)
    at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:32)
    at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:528)
    at java.sql.DriverManager.getConnection(DriverManager.java:571)
    at java.sql.DriverManager.getConnection(DriverManager.java:215)
    at com.ptc.wc.rehost.util.RehostUtils.getDBConnection(RehostUtils.java:567)
    at com.ptc.wc.rehost.validate.DBConnectionValidator.performTask(DBConnectionValidator.java:48)
    at com.ptc.wc.rehost.javatask.AbstractRehostTask.execute(AbstractRehostTask.java:141)
    at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
    at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:606)
    at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
    at org.apache.tools.ant.Task.perform(Task.java:348)
    at org.apache.tools.ant.Target.execute(Target.java:435)
    at org.apache.tools.ant.Target.performTasks(Target.java:456)
    at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1393)
    at org.apache.tools.ant.Project.executeTarget(Project.java:1364)
    at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
    at org.apache.tools.ant.Project.executeTargets(Project.java:1248)
    at org.apache.tools.ant.Main.runBuild(Main.java:851)
    at org.apache.tools.ant.Main.startAnt(Main.java:235)
    at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280)
    at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)
Caused by: oracle.net.ns.NetException: The Network Adapter could not establish the connection
    at oracle.net.nt.ConnStrategy.execute(ConnStrategy.java:439)
    at oracle.net.resolver.AddrResolution.resolveAndExecute(AddrResolution.java:454)
    at oracle.net.ns.NSProtocol.establishConnection(NSProtocol.java:693)
    at oracle.net.ns.NSProtocol.connect(NSProtocol.java:251)
    at oracle.jdbc.driver.T4CConnection.connect(T4CConnection.java:1140)
    at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:340)
    ... 25 more
Caused by: java.net.ConnectException: Connection refused: connect
    at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
    at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
    at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
    at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
    at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
    at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
    at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
    at java.net.Socket.connect(Socket.java:579)
    at oracle.net.nt.TcpNTAdapter.connect(TcpNTAdapter.java:149)
    at oracle.net.nt.ConnOption.connect(ConnOption.java:133)
    at oracle.net.nt.ConnStrategy.execute(ConnStrategy.java:405)
    ... 30 more
I can not solve the error
Thanks for your help
Davide
12 REPLIES 12
TomU
(To:dfante)
"Connection refused".  Sounds like a username/password issue.  I would verify these are correct for the target Oracle server.
dfante
(To:TomU)
Hi Tom,
the password and username is correct.
Not so much like doing 😞
dfante
(To:dfante)
this is the log error:
WARN [Echo]: ***************************************************************
WARN [Echo]: ** Starting Rehost Utility 3.0 M010 B05 20170721 0944 (16) **
WARN [Echo]: modules=rename
INFO [DBConnectionValidator]: RehostProject: OS Name: Windows Server 2008 R2 windows:true prop dir:C:\ptc\conf\rehost.properties
INFO [DBConnectionValidator]: Log may contain passwords? true
INFO [DBConnectionValidator]: Properties for Task:
INFO [DBConnectionValidator]: * Rehost Parameter:rehost.log.passwords=true
* Rehost Parameter:test.prop.values.only=false
target.db.hostname=P04.local
target.db.jdbc.database=
target.db.password=wcadmin
target.db.port=1521
target.db.serviceName=wind
target.db.username=wcadmin
target.db.vendor=oracle
INFO [DBConnectionValidator]: Connecting to jdbc:oracle:thin:@P04.local:1521:wind
INFO [DBConnectionValidator]: with credential: wcadmin
ERROR [DBConnectionValidator]: com.ptc.wc.rehost.exception.RehostException: java.sql.SQLRecoverableException: IO Error: The Network Adapter could not establish the connection
... 25 more
... 30 more
TomU
(To:dfante)
You have to figure out what is preventing communication:
dfante
(To:TomU)
What I do not understand is why it continues to give me the following error when credentials are correct.
WARN [Echo]: ** Starting Rehost Utility 3.0 M010 B05 20170721 1422 (16) **
target.db.password=wcinst
target.db.port=1521
target.db.username=wcinst
INFO [DBConnectionValidator]: with credential: wcinst
ERROR [DBConnectionValidator]: com.ptc.wc.rehost.exception.RehostException: java.sql.SQLException: ORA-01017: invalid username/password; logon denied
Nested exception is: java.sql.SQLException: ORA-01017: invalid username/password; logon denied
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:447)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:389)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:382)
at oracle.jdbc.driver.T4CTTIfun.processError(T4CTTIfun.java:675)
at oracle.jdbc.driver.T4CTTIoauthenticate.processError(T4CTTIoauthenticate.java:448)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:513)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:227)
at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:383)
at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:776)
at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:432)
thank you! But now i have a new error 😞
WARN [Echo]: ** Starting Rehost Utility 3.0 M010 B05 20170721 1526 (16) **
target.db.password=encrypted.wt.pom.dbPassword
target.db.port=1521
ERROR [DBConnectionValidator]: com.ptc.wc.rehost.exception.RehostException: java.sql.SQLException: Listener refused the connection with the following error:
ORA-12505, TNS:listener does not currently know of SID given in connect descriptor
Nested exception is: java.sql.SQLException: Listener refused the connection with the following error:
Caused by: oracle.net.ns.NetException: Listener refused the connection with the following error:
at oracle.net.ns.NSProtocol.connect(NSProtocol.java:399)
... 25 more
Look at line with error.
Searching with that string on KB (support) you can find this article:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS261992
Marco
This article looks more related to Rehost Utility.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS255607
Marco
I'm downloading the patch, I hope to fix it. Thanks Marco
Have you solved your issue?
In affirmative case, could you please mark the right answer as correct?
Marco
Hello Marco,
Sorry but in the end I resolved again from zero
