I am trying below piece of code to publish publication structure using publishing rule. Can anyone guide me if anything wrong in what I am trying.
Publisher pub = new Publisher();I am getting the below error in methodserver.
String objRef = ObjectReference.newObjectReference(pubStruct).toString();
if(!(WorkInProgressHelper.isCheckedOut(pubStruct))) {
String actionString = "<wvsoptions>pubrulename=PS PDF **** Publishing Rule";
boolean result = pub.doPublish(false, true, objRef,
(ConfigSpec) null,
(ConfigSpec) null, true, "Sample_Rep", "Sample_Rep_Desc",
Publisher.EPM, actionString, 0);
wt.wvs.content.FileHelper - null java.lang.NullPointerException at wt.pom.PersistentObjectManager.expand(PersistentObjectManager.java:1409) at wt.fc.StandardPersistenceManager.expand(StandardPersistenceManager.java:3121) at wt.fc.StandardPersistenceManager.navigate(StandardPersistenceManager.java:497) at jdk.internal.reflect.GeneratedMethodAccessor357.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:566) at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399) at com.sun.proxy.$Proxy29.navigate(Unknown Source) at wt.content.StandardContentService.getContentsByRole(StandardContentService.java:2984) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:566) at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399) at com.sun.proxy.$Proxy67.getContentsByRole(Unknown Source) at com.ptc.wvs.server.util.FileHelper.getEdzFile(FileHelper.java:1242) at com.ptc.wvs.server.util.FileHelper.getEdzFile(FileHelper.java:1226) at com.ptc.wvs.server.publish.Publish.newPublishJobInstances(Publish.java:984) at com.ptc.wvs.server.publish.Publish.executePublish(Publish.java:1889) at com.ptc.wvs.server.publish.Publish.executePublish(Publish.java:1838) at com.ptc.wvs.server.publish.Publish.executePublish(Publish.java:705) at com.ptc.wvs.server.publish.Publish.doPublish(Publish.java:551) at com.ptc.wvs.server.publish.Publish.doPublish(Publish.java:360) at com.ptc.wvs.common.ui.Publisher.doClientPublish(Publisher.java:540) at com.ptc.wvs.common.ui.Publisher.doPublish(Publisher.java:494)
Kindly help.
