Hi community!
I want to get the values of some attributes from the users from the task.
When I define an attribute to the activity, I do this by selecting the required option, but when I do this, it wants to get that value as mandatory.
How can I make attributes mandatory in task?
would you share some screenshots to better understand the issue (change task /workflow task ) , are the task using change tasks templates ?
maybe https://www.ptc.com/en/support/article/CS35488 can help.
Hi @Fadel,
I add a variable in the task as shown in the picture.
Since this makes the variable mandatory, it is necessary to close it after filling the text box.
But I want users to leave it blank whenever they want.
Hi , is this a change task ?
no, ticket task
Ticket from Servigistics field Management ?
No, I need to use windchill tickets. I need to customize these tasks
Hi @smcvr
I just haven't get a point.
You asked for the configuration how to set attribute mandatory.
Then you said that you want to do not force users to fill that attribute.
What is the point what Iam missing ?
PetrH
Hi @HelesicPetr ,
Sorry, I wrote the question wrong.
When I add it to the Variables task, it automatically becomes mandatory.
I want this obligation to be removed
