Getting attribute value from task
smcvr
Hi community!
I want to get the values of some attributes from the users from the task.
When I define an attribute to the activity, I do this by selecting the required option, but when I do this, it wants to get that value as mandatory.
How can I make attributes mandatory in task?
HelesicPetr
22-Sapphire I
(To:smcvr)
Hi @smcvr
So you need to change it in the workflow variable.
PetrH
10 REPLIES 10
Fadel
22-Sapphire I
(To:smcvr)
would you share some screenshots to better understand the issue (change task /workflow task ) , are the task using change tasks templates  ?
maybe https://www.ptc.com/en/support/article/CS35488 can help.
Fede
smcvr
(To:Fadel)
Hi @Fadel,
I add a variable in the task as shown in the picture.
Since this makes the variable mandatory, it is necessary to close it after filling the text box.
But I want users to leave it blank whenever they want.
Fadel
22-Sapphire I
(To:smcvr)
Hi , is this a change task ?
Fede
smcvr
(To:Fadel)
no, ticket task
Fadel
22-Sapphire I
(To:smcvr)
Ticket from Servigistics field Management  ?
Fede
smcvr
(To:Fadel)
No, I need to use windchill tickets. I need to customize these tasks
HelesicPetr
22-Sapphire I
(To:smcvr)
Hi @smcvr
I just haven't get a point.
You asked for the configuration how to set attribute mandatory.
Then you said that you want to do not force users to fill that attribute.
What is the point what Iam missing ?
PetrH
smcvr
(To:HelesicPetr)
Hi @HelesicPetr ,
Sorry, I wrote the question wrong.
When I add it to the Variables task, it automatically becomes mandatory.
I want this obligation to be removed
HelesicPetr
22-Sapphire I
(To:smcvr)
Hi @smcvr
PetrH
smcvr
(To:HelesicPetr)
@HelesicPetr  and @Fadel  Thanks for your help
