Hello everyone!
Please tell me how can I get the values of global attributes in a WTDocument using OData?
Version of Windchill REST Services - 1.4.
Now I can only get attributes such as number and name.
Thanks in advance.
Regards!
Hi VladiSlav,
Please refer to this helpful article :
https://www.ptc.com/en/support/article/CS304928
If you have a simple IBA, you just have to add in Parts.json the following :
"name":"IBA",
"internalName":"IBA",
"type":"String"
Create an entry in Parts.json, specifying a new attribute. As it is an enumeration, I will add the following :
"name": "EnumString",
"internalName": "EnumString",
"type": "PTC.EnumType"
In Parts.json, findable in codebase\rest\ptc\domain\ProdMgmt\v2\entity\Parts.json
Then it will look like this :
"name":"Part",
"collectionName":"Parts",
"type":"wcType",
"wcType":"wt.part.WTPart",
"description":"Parts",
"operations":"CREATE,UPDATE,DELETE",
"attributes":[
"name":"Name",
"internalName":"name",
"type":"String",
"required":true
"name":"Number",
"internalName":"number",
"type":"String"
"name":"EndItem",
"internalName":"endItem",
"type":"Boolean",
"driver":true
"name":"TypeIcon",
"internalName":"type_icon",
"type":"PTC.Icon",
"readOnly":true
"name":"Identity",
"internalName":"identity",
"type":"String",
"readOnly":true
"name":"GeneralStatus",
"internalName":"statusFamily_General",
"type":"PTC.Icon",
"readOnly":true
"name":"ShareStatus",
"internalName":"statusFamily_Share",
"type":"PTC.Icon",
"readOnly":true
"name":"ChangeStatus",
"internalName":"statusFamily_Change",
"type":"PTC.Icon",
"readOnly":true
"name":"Supersedes",
"internalName":"statusFamily_Supersede",
"type":"PTC.Icon",
"readOnly":true
"name":"AssemblyMode",
"internalName":"partType",
"type":"PTC.EnumType",
"required":true
"name":"DefaultUnit",
"internalName":"defaultUnit",
"required":true
"name":"DefaultTraceCode",
"internalName":"defaultTraceCode",
"required":true
"name":"Source",
"internalName":"source",
"required":true
"name":"ConfigurableModule",
"internalName":"genericType",
"name":"GatheringPart",
"internalName":"hidePartInStructure",
"type":"Boolean",
"required":true
"name":"PhantomManufacturingPart",
"internalName":"phantom",
"type":"Boolean",
"required":true
"name":"BOMType",
"internalName":"variation1",
"name":"AlternateNumber",
"internalName":"variation2",
"inherits":[
"name": "versioned"
"name": "contextManaged"
"name": "lifecycleManaged"
"name": "viewManageable"
"name": "workable"
"name": "representable"
"name": "organizationOwned"
"name": "foldered"
"navigations":[
"name":"Uses",
"target":"PartUses",
"type":"PartUse",
"isCollection":true,
"containsTarget":true
"name":"UsedBy",
"target":"Parts",
"type":"Part",
"isCollection":true
"name":"DescribedBy",
"target":"PartDescribeLinks",
"type":"PartDescribeLink",
"name":"References",
"target":"PartReferenceLinks",
"type":"PartReferenceLink",
"functions":[],
"actions":[
"name":"GetBOM",
"description":"Get Bill Of Materials",
"parameters": [{
"name":"part",
"type":"Part",
"isNullable":false,
"isCollection":false
"name":"navigationCriteriaId",
"type":"String",
"isNullable":true,
"returnType": {
"type":"BOM",
Without restarting Windchill :
GET http://pdm10.de/Windchill/servlet/odata/ProdMgmt/Parts('VR:wt.part.WTPart:2874036') In Postman
Give this output :
"@odata.context": "http://pdm10.de/Windchill/servlet/odata/v2/ProdMgmt/$metadata#Parts",
"@odata.type": "#PTC.ProdMgmt.AsArticle",
"ID": "OR:wt.part.WTPart:2874037",
"Name": "MyPar",
"Number": "0000071301",
"EndItem": false,
"TypeIcon": {
"Path": "http://pdm10.de/Windchill/netmarkets/images/config_part.gif",
"Tooltip": "Configurable Module"
"Identity": "0000071301, MyPar, Demo Organization, A (Design)",
"GeneralStatus": {
"Path": "http://pdm10.de/Windchill/com/ptc/core/htmlcomp/images/checkedout_byyou9x9.gif",
"Tooltip": "Working copy, checked-out to you"
"ShareStatus": null,
"ChangeStatus": null,
"Supersedes": null,
"AssemblyMode": {
"Value": "separable",
"Display": "Separable"
"DefaultUnit": {
"Value": "ea",
"Display": "each"
"DefaultTraceCode": {
"Value": "0",
"Display": "Untraced"
"Source": {
"Value": "make",
"Display": "Make"
"ConfigurableModule": {
"Value": "dynamic",
"Display": "Yes"
"GatheringPart": false,
"PhantomManufacturingPart": false,
"BOMType": null,
"AlternateNumber": null,
"EnumString": {
"Value": "SteelSheets",
"Display": "Steel Sheets"
"View": "Design",
"CheckoutState": "Working copy, checked-out to you",
"CheckOutStatus": "cat-working-copy",
"Comments": null,
"State": {
"Value": "INWORK",
"Display": "In Work"
if it does not work please expose here how you are driving this use case.
best regards
Hicham
Hi VladiSlav,
"name":"IBA",
"type":"String"
"name":"Part",
"type":"wcType",
"attributes":[
"name":"Name",
"type":"String",
"required":true
"name":"Number",
"type":"String"
"name":"EndItem",
"type":"Boolean",
"driver":true
"name":"TypeIcon",
"type":"PTC.Icon",
"readOnly":true
"name":"Identity",
"type":"String",
"readOnly":true
"type":"PTC.Icon",
"readOnly":true
"type":"PTC.Icon",
"readOnly":true
"type":"PTC.Icon",
"readOnly":true
"type":"PTC.Icon",
"readOnly":true
"required":true
"required":true
"required":true
"name":"Source",
"required":true
"type":"Boolean",
"required":true
"type":"Boolean",
"required":true
"name":"BOMType",
"inherits":[
"name": "versioned"
"name": "workable"
"name": "foldered"
"navigations":[
"name":"Uses",
"type":"PartUse",
"name":"UsedBy",
"target":"Parts",
"type":"Part",
"isCollection":true
"functions":[],
"actions":[
"name":"GetBOM",
"parameters": [{
"name":"part",
"type":"Part",
"isNullable":false,
"type":"String",
"isNullable":true,
"returnType": {
"type":"BOM",
Give this output :
"Name": "MyPar",
"EndItem": false,
"TypeIcon": {
"GeneralStatus": {
"Supersedes": null,
"AssemblyMode": {
"DefaultUnit": {
"Value": "ea",
"Display": "each"
"Value": "0",
"Source": {
"Value": "make",
"Display": "Make"
"Value": "dynamic",
"Display": "Yes"
"BOMType": null,
"EnumString": {
"View": "Design",
"Comments": null,
"State": {
"Value": "INWORK",
best regards
Hicham
Thank you very much for your reply!
I added these lines to Documents.json:
"name":"IBA",
"type":"String"
And I get these answers to the request:
<d:EnumString m:null="true"/>
<d:IBA m:null="true"/>
here is the main part of my request:
Windchill/servlet/odata/v1/DocMgmt/Documents
What am I doing wrong?
Thanks in advance!
But what are the internal names of your global attributes ? (in type and attribute manager)
Hicham
oh sure!
Now everything worked, thanks a lot!
One more question if you can)
I used to think that enumerations have only one name and several values.
But in your example it looks like a key - value.
"EnumString": {
Do I understand correctly?
How can I do it?
Thanks in advance!
HI, follow these screenshots :
create an IBA and add constraint enumeration
the global enumeratoin to be added into the IBA
after creating a part and added a value to the attribute
Postman response
Hope this is now clear 🙂
Best reagrds,
Hicham
Thank you so much!
