Getting global attributes of WTDocument by OData
VladiSlav
Hello everyone!
Please tell me how can I get the values of global attributes in a WTDocument using OData?
Version of Windchill REST Services - 1.4.
Now I can only get attributes such as number and name.
Thanks in advance.
Regards!
hlafkir
(To:VladiSlav)
Hi VladiSlav,
Please refer to this helpful article :
https://www.ptc.com/en/support/article/CS304928
If you have a simple IBA, you just have to add in Parts.json the following :
"name":"IBA",
"internalName":"IBA",
"type":"String"
  • Here an illustration with a custom enumtype (adding an IBA linked to a  Global Enumeration).
Create an entry in Parts.json, specifying a new attribute. As it is an enumeration, I will add the following :
                               "name": "EnumString",
"internalName": "EnumString",
"type": "PTC.EnumType"
In Parts.json, findable in codebase\rest\ptc\domain\ProdMgmt\v2\entity\Parts.json
Then it will look like this :
    "name":"Part",
    "collectionName":"Parts",
    "type":"wcType",
    "wcType":"wt.part.WTPart",
    "description":"Parts",
    "operations":"CREATE,UPDATE,DELETE",
    "attributes":[
         "name":"Name",
         "internalName":"name",
         "type":"String",
         "required":true
         "name":"Number",
         "internalName":"number",
         "type":"String"
         "name":"EndItem",
         "internalName":"endItem",
         "type":"Boolean",
         "driver":true
          "name":"TypeIcon",
          "internalName":"type_icon",
          "type":"PTC.Icon",
          "readOnly":true
          "name":"Identity",
          "internalName":"identity",
          "type":"String",
          "readOnly":true
          "name":"GeneralStatus",
          "internalName":"statusFamily_General",
          "type":"PTC.Icon",
          "readOnly":true
          "name":"ShareStatus",
          "internalName":"statusFamily_Share",
          "type":"PTC.Icon",
          "readOnly":true
          "name":"ChangeStatus",
          "internalName":"statusFamily_Change",
          "type":"PTC.Icon",
          "readOnly":true
          "name":"Supersedes",
          "internalName":"statusFamily_Supersede",
          "type":"PTC.Icon",
          "readOnly":true
          "name":"AssemblyMode",
          "internalName":"partType",
          "type":"PTC.EnumType",
          "required":true
          "name":"DefaultUnit",
          "internalName":"defaultUnit",
          "required":true
          "name":"DefaultTraceCode",
          "internalName":"defaultTraceCode",
          "required":true
          "name":"Source",
          "internalName":"source",
          "required":true
          "name":"ConfigurableModule",
          "internalName":"genericType",
          "name":"GatheringPart",
          "internalName":"hidePartInStructure",
          "type":"Boolean",
          "required":true
          "name":"PhantomManufacturingPart",
          "internalName":"phantom",
          "type":"Boolean",
          "required":true
          "name":"BOMType",
          "internalName":"variation1",
          "name":"AlternateNumber",
          "internalName":"variation2",
    "inherits":[
            "name": "versioned"
            "name": "contextManaged"
            "name": "lifecycleManaged"
            "name": "viewManageable"
            "name": "workable"
            "name": "representable"
            "name": "organizationOwned"
            "name": "foldered"
    "navigations":[
         "name":"Uses",
         "target":"PartUses",
         "type":"PartUse",
         "isCollection":true,
         "containsTarget":true
         "name":"UsedBy",
         "target":"Parts",
         "type":"Part",
         "isCollection":true
         "name":"DescribedBy",
         "target":"PartDescribeLinks",
         "type":"PartDescribeLink",
         "name":"References",
         "target":"PartReferenceLinks",
         "type":"PartReferenceLink",
    "functions":[],
    "actions":[
          "name":"GetBOM",
          "description":"Get Bill Of Materials",
          "parameters": [{
              "name":"part",
              "type":"Part",
              "isNullable":false,
              "isCollection":false
              "name":"navigationCriteriaId",
              "type":"String",
              "isNullable":true,
          "returnType": {
              "type":"BOM",
Without restarting Windchill :
GET http://pdm10.de/Windchill/servlet/odata/ProdMgmt/Parts('VR:wt.part.WTPart:2874036') In Postman
Give this output :
    "@odata.context""http://pdm10.de/Windchill/servlet/odata/v2/ProdMgmt/$metadata#Parts",
    "@odata.type""#PTC.ProdMgmt.AsArticle",
    "ID""OR:wt.part.WTPart:2874037",
    "Name""MyPar",
    "Number""0000071301",
    "EndItem"false,
    "TypeIcon": {
        "Path""http://pdm10.de/Windchill/netmarkets/images/config_part.gif",
        "Tooltip""Configurable Module"
    "Identity""0000071301, MyPar, Demo Organization, A (Design)",
    "GeneralStatus": {
        "Path""http://pdm10.de/Windchill/com/ptc/core/htmlcomp/images/checkedout_byyou9x9.gif",
        "Tooltip""Working copy, checked-out to you"
    "ShareStatus"null,
    "ChangeStatus"null,
    "Supersedes"null,
    "AssemblyMode": {
        "Value""separable",
        "Display""Separable"
    "DefaultUnit": {
        "Value""ea",
        "Display""each"
    "DefaultTraceCode": {
        "Value""0",
        "Display""Untraced"
    "Source": {
        "Value""make",
        "Display""Make"
    "ConfigurableModule": {
        "Value""dynamic",
        "Display""Yes"
    "GatheringPart"false,
    "PhantomManufacturingPart"false,
    "BOMType"null,
    "AlternateNumber"null,
    "EnumString": {
        "Value""SteelSheets",
        "Display""Steel Sheets"
    "View""Design",
    "CheckoutState""Working copy, checked-out to you",
    "CheckOutStatus""cat-working-copy",
    "Comments"null,
    "State": {
        "Value""INWORK",
        "Display""In Work"
if it does not work please expose here how you are driving this use case.
best regards
Hicham
7 REPLIES 7
hlafkir
(To:VladiSlav)
Hi VladiSlav,
"name":"IBA",
"type":"String"
    "name":"Part",
    "type":"wcType",
    "attributes":[
         "name":"Name",
         "type":"String",
         "required":true
         "name":"Number",
         "type":"String"
         "name":"EndItem",
         "type":"Boolean",
         "driver":true
          "name":"TypeIcon",
          "type":"PTC.Icon",
          "readOnly":true
          "name":"Identity",
          "type":"String",
          "readOnly":true
          "type":"PTC.Icon",
          "readOnly":true
          "type":"PTC.Icon",
          "readOnly":true
          "type":"PTC.Icon",
          "readOnly":true
          "type":"PTC.Icon",
          "readOnly":true
          "required":true
          "required":true
          "required":true
          "name":"Source",
          "required":true
          "type":"Boolean",
          "required":true
          "type":"Boolean",
          "required":true
          "name":"BOMType",
    "inherits":[
            "name": "versioned"
            "name": "workable"
            "name": "foldered"
    "navigations":[
         "name":"Uses",
         "type":"PartUse",
         "name":"UsedBy",
         "target":"Parts",
         "type":"Part",
         "isCollection":true
    "functions":[],
    "actions":[
          "name":"GetBOM",
          "parameters": [{
              "name":"part",
              "type":"Part",
              "isNullable":false,
              "type":"String",
              "isNullable":true,
          "returnType": {
              "type":"BOM",
Give this output :
    "Name""MyPar",
    "EndItem"false,
    "TypeIcon": {
    "GeneralStatus": {
    "ShareStatus"null,
    "ChangeStatus"null,
    "Supersedes"null,
    "AssemblyMode": {
        "Value""separable",
    "DefaultUnit": {
        "Value""ea",
        "Display""each"
        "Value""0",
        "Display""Untraced"
    "Source": {
        "Value""make",
        "Display""Make"
        "Value""dynamic",
        "Display""Yes"
    "BOMType"null,
    "EnumString": {
    "View""Design",
    "Comments"null,
    "State": {
        "Value""INWORK",
        "Display""In Work"
best regards
Hicham
VladiSlav
(To:hlafkir)
Thank you very much for your reply!
I added these lines to Documents.json:
 "name":"IBA",
 "type":"String"
And I get these answers to the request:
<d:EnumString m:null="true"/>
<d:IBA m:null="true"/>
here is the main part of my request:
Windchill/servlet/odata/v1/DocMgmt/Documents
What am I doing wrong?
Thanks in advance!
hlafkir
(To:VladiSlav)
But what are the internal names of your global attributes ? (in type and attribute manager)
Hicham
VladiSlav
(To:hlafkir)
oh sure!
Now everything worked, thanks a lot!
VladiSlav
(To:hlafkir)
One more question if you can)
I used to think that enumerations have only one name and several values.
But in your example it looks like a key - value.
"EnumString": {
"Value": "SteelSheets",
"Display": "Steel Sheets"
Do I understand correctly?
How can I do it?
Thanks in advance!
hlafkir
(To:VladiSlav)
HI, follow these screenshots :
create an IBA and add constraint enumerationcreate an IBA and add constraint enumerationthe global enumeratoin to be added into the IBAthe global enumeratoin to be added into the IBAafter creating a part and added a value to the attributeafter creating a part and added a value to the attributePostman responsePostman response
Hope this is now clear 🙂
Best reagrds,
Hicham
VladiSlav
(To:hlafkir)
Thank you so much!
