Feb 7, 2023 9:30 AM UTC
Hide Primary Content field in WTDocument subtype
Hello All,
I have a requirement where I have to hide the field Primary Content in the create and edit layout of WTDocument. I understand that it is not a part of PDM functionality but I would like to customize this and keep the primary content hidden in the form. Requesting you to shed some light on the options.
Sha
Sha11Answer
Feb 22, 2023 2:39 PM UTC
The below customization done in documentManagement.js took care of this requirement.
function updatePrimaryContent(value){
if(value == 'wt.doc.WTDocument|typeName of the Document'){
document.getElementById("primary0contentSourceList").selectedIndex = 0;
document.getElementById("templatePickerDiv").style.display = "none";
//This if will hide primary content selection block
var primaryContentContainer = null;
else{
var primaryContentContainer = document.getElementById('primaryContentPullDown');
//var primaryContentContainer = document.getElementById('primaryContentPullDown');
var keepCheckoutDiv = document.getElementById('checkboxkeepCheckedOutDiv');
var attrPanelDiv = document.getElementById('setAttributesTablePane');
var horizontalLine = document.getElementById('primaryContentHzLine');
var insertLocationPickerDiv = document.getElementById('insertLocationPickerDiv');
if(value!=''){
if (primaryContentContainer != null){
primaryContentContainer.style.visibility = 'visible';
if (keepCheckoutDiv != null){
keepCheckoutDiv.style.visibility = 'visible';
if (attrPanelDiv != ''){
attrPanelDiv.style.visibility = 'visible';
if (horizontalLine != ''){
horizontalLine.style.visibility = 'visible';
if (insertLocationPickerDiv != null) {
insertLocationPickerDiv.style.visibility = 'visible';
}else{
primaryContentContainer.style.visibility = 'hidden';
keepCheckoutDiv.style.visibility = 'hidden';
attrPanelDiv.style.visibility = 'hidden';
horizontalLine.style.visibility = 'hidden';
function displayPrimaryContent(){
//This block will hide file selection and file description in primary Content
var type = document.getElementById('createType').value;
if(type == 'wt.doc.WTDocument|documentType Name'){
hideElement('primaryFileWidgets');
hideElement('primaryURLWidgets');
hideElement('primaryExternalWidgets');
hideElement('primarySCMWidgets');
else{
var source;
var sourceList = document.getElementById('primary0contentSourceList');
var scmField = document.getElementById('scmHiddenField');
if( scmField != null && typeof scmField != 'undefined' )
manageSCMConent(sourceList);
if (sourceList!=null && typeof sourceList!= 'undefined' ){
source=sourceList.value;
}else{
return;
// then show whatever's appropriate
// ***MEC get strings from Java constants
if ( source=="URL" ) {
showElement('primaryURLWidgets');
} else if ( source=="EXTERNAL" ) {
showElement('primaryExternalWidgets');
} else if ( source=="CLEARCASE" ) {
showElement('primarySCMWidgets');
} else if ( source=="FILE" ) {
showElement('primaryFileWidgets');
Feb 8, 2023 4:14 AM UTC
Hello Sha,
          Yes, it is not a part of the Windchill functionality and is not officially supported.
However, one file you probably want to do some experiment:  netmarkets/javascript/documentManagement.js
Sha1114-AlexandriteAuthor
Feb 8, 2023 6:02 AM UTC
Been experimenting with the same file for the past 2 days, no luck so far.
HelesicPetr
Feb 8, 2023 8:38 AM UTC
Hi @Sha11
@Joe_Sun give you good hint.
You need to get selected type of WTDocument and basend on it show or hide the primary content panel
change the visible to hidden
example with type control
		if (value=="YOURDOCTYPE")
		}else{
Then you need to preselect no content to achieve that wizard does not force you to select upload content.
PetrH
Sha1114-AlexandriteAuthorAnswer
else{
if(value!=''){
}else{
else{
var source;
}else{
return;
HelesicPetr
Feb 22, 2023 2:44 PM UTC
This looks better 😄
 else{
 if(value!=''){
 }else{
 else{
 var source;
 }else{
 return;
11-Garnet
Apr 28, 2023 4:02 PM UTC
I tried the same approach in my system. But i dont see any changes reflected. Can anyone guide through
