Hide Primary Content field in WTDocument subtype
Sha11
Hello All,
I have a requirement where I have to hide the field Primary Content in the create and edit layout of WTDocument. I understand that it is not a part of PDM functionality but I would like to customize this and keep the primary content hidden in the form. Requesting you to shed some light on the options.
Sha
Sha11
(To:Sha11)
The below customization done in documentManagement.js took care of this requirement.
function updatePrimaryContent(value){
if(value == 'wt.doc.WTDocument|typeName of the Document'){
document.getElementById("primary0contentSourceList").selectedIndex = 0;
document.getElementById("templatePickerDiv").style.display = "none";
//This if will hide primary content selection block
var primaryContentContainer = null;
else{
var primaryContentContainer = document.getElementById('primaryContentPullDown');
//var primaryContentContainer = document.getElementById('primaryContentPullDown');
var keepCheckoutDiv = document.getElementById('checkboxkeepCheckedOutDiv');
var attrPanelDiv = document.getElementById('setAttributesTablePane');
var horizontalLine = document.getElementById('primaryContentHzLine');
var insertLocationPickerDiv = document.getElementById('insertLocationPickerDiv');
if(value!=''){
if (primaryContentContainer != null){
primaryContentContainer.style.visibility = 'visible';
if (keepCheckoutDiv != null){
keepCheckoutDiv.style.visibility = 'visible';
if (attrPanelDiv != ''){
attrPanelDiv.style.visibility = 'visible';
if (horizontalLine != ''){
horizontalLine.style.visibility = 'visible';
if (insertLocationPickerDiv != null) {
insertLocationPickerDiv.style.visibility = 'visible';
}else{
primaryContentContainer.style.visibility = 'hidden';
keepCheckoutDiv.style.visibility = 'hidden';
attrPanelDiv.style.visibility = 'hidden';
horizontalLine.style.visibility = 'hidden';
function displayPrimaryContent(){
//This block will hide file selection and file description in primary Content
var type = document.getElementById('createType').value;
if(type == 'wt.doc.WTDocument|documentType Name'){
hideElement('primaryFileWidgets');
hideElement('primaryURLWidgets');
hideElement('primaryExternalWidgets');
hideElement('primarySCMWidgets');
else{
var source;
var sourceList = document.getElementById('primary0contentSourceList');
var scmField = document.getElementById('scmHiddenField');
if( scmField != null && typeof scmField != 'undefined' )
manageSCMConent(sourceList);
if (sourceList!=null && typeof sourceList!= 'undefined' ){
source=sourceList.value;
}else{
return;
// then show whatever's appropriate
// ***MEC get strings from Java constants
if ( source=="URL" ) {
showElement('primaryURLWidgets');
} else if ( source=="EXTERNAL" ) {
showElement('primaryExternalWidgets');
} else if ( source=="CLEARCASE" ) {
showElement('primarySCMWidgets');
} else if ( source=="FILE" ) {
showElement('primaryFileWidgets');
11 REPLIES 11
Joe_Sun
(To:Sha11)
Hello Sha,
          Yes, it is not a part of the Windchill functionality and is not officially supported.
However, one file you probably want to do some experiment:  netmarkets/javascript/documentManagement.js
Sha11
(To:Joe_Sun)
Been experimenting with the same file for the past 2 days, no luck so far.
HelesicPetr
(To:Sha11)
Hi @Sha11
@Joe_Sun give you good hint.
You need to get selected type of WTDocument and basend on it show or hide the primary content panel
change the visible to hidden
example with type control
		if (value=="YOURDOCTYPE")
		}else{
Then you need to preselect no content to achieve that wizard does not force you to select upload content.
PetrH
Sha11
(To:HelesicPetr)
@HelesicPetr ,
I believe you are talking about updatePrimaryContent() method in documentManagement.js, I did try updating that method and it did not hide the Primary Content field as expected. I introduced an if condition to that method to validate type value, but it not seem to take effect after selecting the document type in the Type dropdown.
HelesicPetr
(To:Sha11)
Hi @Sha11
Do you use correct type value string? Do you have real value from  variable? do you compare correct value?
For example Minutes string ´= wt.doc.WTDocument|cz.aveng.in.skol.Minutes
It has to work.
PetrH
Sha11
(To:HelesicPetr)
Hello @HelesicPetr ,
Thank you for the input, and yes, I used the correct type name only, the issue that I am facing is, after implementing those changes, the Primary Content field is getting hidden but the create WTDocument form still expects some value for Primary Content and is not allowing me to create an object. I am now looking for a way to default the Primary Content selection to No Content and then hide the field.
HelesicPetr
(To:Sha11)
Yes this is an another issue as a consequence that needs to be solved 😄
PetrH
It could be, that the preference is set, that a primary file is necessary and not optional.
Sha11
(To:Sha11)
else{
if(value!=''){
}else{
else{
var source;
}else{
return;
HelesicPetr
(To:Sha11)
This looks better 😄
    else{
    if(value!=''){
    }else{
    else{
        var source;
        }else{
            return;
I tried the same approach in my system. But i dont see any changes reflected. Can anyone guide through
