How can the "FIle > open pdf" menu be copied from 'Representation / Annotation' under content tab of a drawing published in pdf to search result table ?
vmhala
Is it possible to open the pdf file of a published creo drawing file directly in Acrobat reader from the search results table ?
The menu action is available as "FIle > open pdf" in 'Representation / Annotation' under content tab of a drawing as shown below :Menu.png
This particular link is needed in the search result table as a pdf icon or on the right click of the object listed in search. Note this is specific to drawings published as pdf's.
Your inputs would be highly appreciated.
-Vaibhav
1 REPLY 1
vmhala
(To:vmhala)
Windchillers,
After further investigation and a conversation with PTC its concluded that, Advanced Search table can’t search Derived Image Object. Because this object not model object.  What i was trying to achieve was to bring an object wt.viewmarkup.Derivedimmage into the Advanced search.
Has  anyone come across such a requirement; can a tweak somewhere in the configuration make it possible ? Or is it something just NOT doable.
- Awaiting your insight!
Vabs.
