How can we get the enditem of wtpart subtype?
CH_10078393
6-Contributor
Hi @CH_10078393
What do you need?
Search for specific subtype and all enditems in that subtype?
if yes, then this code will search for the subtype and enditem
final IdentifierFactory IDENTIFIER_FACTORY = (IdentifierFactory) DefaultServiceProvider.getService(IdentifierFactory.class, "logical");
try
	TypeIdentifier tid = (TypeIdentifier) IDENTIFIER_FACTORY.get("com.aveng.SubType"); // Example: subtype=com.ptc.ElectricalPart
	SearchCondition sc = TypedUtilityServiceHelper.service.getSearchCondition(tid, true);
	QuerySpec queryspec = new QuerySpec();
	int idWTPartObject = queryspec.appendClassList(WTPart.class, true);
	// definice typu v sc (andCondition zamenena za sc)
	queryspec.appendWhere(sc, new int[]{idWTPartObject, idWTPartObject});
	queryspec.appendAnd();
	queryspec.appendWhere(new SearchCondition(WTPart.class, WTPart.END_ITEM, SearchCondition.IS_TRUE), new int[]{idWTPartObject});
	queryspec.appendOrderBy(new OrderBy(new ClassAttribute(WTPart.class, WTPart.NUMBER), false), new int[]{0});
	QueryResult resultDocument = PersistenceHelper.manager.find((StatementSpec) queryspec);
	while (resultDocument.hasMoreElements())
		Object obj[] = (Object[]) resultDocument.nextElement();
		if (obj[0] instanceof WTPart)
			WTPart wtp = (WTPart) obj[0];
			System.out.printf("endItem: %s", wtp.getNumber());
} catch (WTException e)
	e.printStackTrace();
PetrH
Hi PetrH,
-> We have PartA , PartB and PartC as sube types of wt part.
-> I want check whether PartC is a enditem or not ?.
How can I do this ?.
Chandra
Hi @CH_10078393
If you have the WTPart object then use simple method on that WTPart
WTPart wtp = (WTPart) primaryBussinessObject;
boolean endItem = wtp.isEndItem();
Or use the previous example to search a specific WTPart number .
You just need to add additional condition with a NUMBER.
If the queryresult contains any results, it means that the wtpart number is enditem...
PetrH
Hi PetrH,
Still doesn't works,
How Can I get the subtype of WTPart ?
Chandra
avillanueva
(To:CH_10078393)
To clarify, you are not asking how to figure out if something is an end item. You are trying to determine if its the type you are looking for.
String type = TypedUtilityServiceHelper.service.getExternalTypeIdentifier(part);
I've used this line above which should show you the soft-type of the part. You can then compare to the logical name part "PartC" matches.
