How does ESI Integration for 'SAP' tyep ESI Target work
Rohaan
Hello All.
Greetings!
I need to establish a connection to new SAP System using SAP as ESI target type.
Need to trigger this transaction with XML to some SAP Integration suite (Cloud Integration)
Would appreciate any assistance on how to configure ESI target in windchill system and is there any preference to input "Endpoint URL" and Username password provided to enable this connection
Is there any way I can obtain "Client" and "SystemID" values from URL
avillanueva
23-Emerald I
(To:Rohaan)
This is what your setup for Distribution Target should look like (File):
You need the full ESI and Tibco to talk directly to SAP. https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FESIDistTargetCreate.html
I am using the connector and it is setup to output to a file (XML) that I have a customization in SAP to create in and create iDocs for.
https://www.ptc.com/en/support/article/CS111663?source=search
avillanueva
23-Emerald I
(To:Rohaan)
Are you using ERP Connector or full ESI integration with Tibco?
Rohaan
(To:avillanueva)
ERP Connector
avillanueva
23-Emerald I
(To:Rohaan)
