How to Reuse OOTB Rename functionality under a new name, like MyRename
vuchekar
Hi All,
I want to Reuse existing OOTB Rename functionality under an new name like, My Rename, where and in which files i have to do modifications ?
Any help.
Vivek
2 REPLIES 2
Hi Vivek,
Rename functionality uses Template processor architecture, are you trying to replicate the entire UI with the collector options or is there any particular customization that you want to add in the Rename UI?
Bhushan
Hi Bhushan,
Thanks for your response.
I want to use the existing Rename functionality under a my custom name.
my goal is to achieve Renaming objects irrespective of objects life cycle states and user's ACL.
if its possible to replicate entire UI with the collector options, then its good.
Vivek
