Version: Windchill 12.0
Use Case: assume for example if am creating new part and type should be A. i need to select lifecycletemplate based on type. it should show the lifecycle template drop down like A,B, C etc.
Description:
Hi @GK_12349054,
Kindly refer to the following article to implement the requirement.
Hi @GK_12349054,
