How to check WTPart if which is don't have parent using Info-engine
ukrishnan-3
11-Garnet
Version: Windchill 12.1
Use Case: How to check WTPart if which is don't have parent using Info-engine
Description:
Hi @ukrishnan-3 ,
You can leverage Query-Links Webject available Out-Of-The-Box.
Example of Query-Links Webject is given in article:
How to implement/use the "Query-Links" webject in Windchill PDMLink
Also, you can refer to Help Center Topic : Query-Links (ptc.com)
Bhushan Dhamdhere
Hi @ukrishnan-3 ,
Bhushan Dhamdhere
Hello @ukrishnan-3
It looks like you have a response on your topic. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
