How to check if downstream view of the WT part exists?
Dina_S
Hi All,
I want to create a "Manufacturing" view for the part included in the Change task, but I want to do it only if it doesn't exist.
Now I use this code without checking. And I want to add something like " if Manufacturing view for obj ==null then"
wt.fc.QueryResult qr = wt.change2.ChangeHelper2.service.getChangeablesBefore((wt.change2.ChangeOrderIfc) primaryBusinessObject);
while(qr.hasMoreElements())
  wt.fc.WTObject  obj =(wt.fc.WTObject) qr.nextElement();
   if(obj instanceof wt.part.WTPart)
       wt.part.WTPart prt = (wt.part.WTPart) obj;
       wt.part.WTPart ManufPart = (wt.part.WTPart)
       ManufPart = (wt.vc.views.ViewManageable)obj, "Manufacturing")
       wt.vc.views.ViewHelper.service.newBranchForView((wt.vc.views.ViewManageable)obj, "Manufacturing");
      ManufPart = (wt.part.WTPart)wt.fc.PersistenceHelper.manager.store(ManufPart);
HelesicPetr
22-Sapphire I
(To:Dina_S)
Hi @Dina_S
It is easy.
Filter the results based on your view
QueryResult qrUstr = PersistenceHelper.manager.navigate(part,EquivalenceLink.DOWNSTREAM_ROLE,wt.associativity.EquivalenceLink.class, true);
		WTPart dwWTP = null;
		while (qrUstr.hasMoreElements())
			dwWTP = (WTPart) qrUstr.nextElement();
			if (dwWTP.getViewName().equalsIgnoreCase("manufacturing"))
				System.out.print(dwWTP.getNumber()); // use it as you need.
PetrH
Dina_S
(To:Dina_S)
I have found this
https://www.ptc.com/en/support/article/cs47538?language=en&posno=4&q=ViewHelper.service.newBranchForView&source=search
wt.fc.PersistenceHelper.manager.navigate(reference.getObject(),wt.associativity.EquivalenceLink.DOWNSTREAM_ROLE, wt.associativity.EquivalenceLink.class);
I need help finding out how to use this. I need only the "Manufacturing view" part, not the "Service view" one. And I don't know how to check the assigned view for the object. I would really appreciate it if someone could help me.
So I tried this and it doesn't work like I want:
wt.fc.QueryResult AllDownPart = wt.fc.PersistenceHelper.manager.navigate(obj,
wt.associativity.EquivalenceLink.DOWNSTREAM_ROLE, wt.associativity.EquivalenceLink.class,true);
if(AllDownPart != null){
HelesicPetr
22-Sapphire I
(To:Dina_S)
Hi @Dina_S
It is easy.
PetrH
Dina_S
(To:HelesicPetr)
Thank you for the clue.
Dina_S
(To:HelesicPetr)
It is also important not to forget to create an Equivalence link.
The object is taken from Change Notice.
Below full working code without checking procedures:
	//qr changeable before= vector all Deign part for Manufacturing
   //obj =one design part from implementation tasks
	   wt.fc.QueryResult AllDown = wt.fc.PersistenceHelper.manager.navigate(prt, wt.associativity.EquivalenceLink.DOWNSTREAM_ROLE, wt.associativity.EquivalenceLink.class,true);
	//all downstream parts
	   wt.part.WTPart ManuPart= null;
	// empty part for Manufacturing
	  wt.part.WTPart dwWTP = null;
   // empty part for checking if Manufacturing
	 while (AllDown.hasMoreElements())
			dwWTP = (wt.part.WTPart) AllDown.nextElement();
			if (dwWTP.getViewName().equalsIgnoreCase("Manufacturing"))
				ManuPart = dwWTP;
	if(ManuPart==null)
	  ManuPart = (wt.part.WTPart)wt.vc.views.ViewHelper.service.newBranchForView((wt.vc.views.ViewManageable)prt, "Manufacturing");
	  ManuPart = (wt.part.WTPart)wt.fc.PersistenceHelper.manager.store(ManuPart);
	  //create equivelencelink between these 2 parts
		wt.associativity.EquivalenceLink link1 = wt.associativity.EquivalenceLink.newEquivalenceLink(prt,ManuPart);
		link1.setIsConsumable(true);
		link1.setUpstreamContextRef(prt.getView());
		link1.setDownstreamContextRef(ManuPart.getView());
		link1 = (wt.associativity.EquivalenceLink) wt.fc.PersistenceHelper.manager.save(link1);
Dina_S
(To:Dina_S)
 I also found that it is important not to forget to create EquivalenceLink :).
