In Structure Tab can not find uses tab. This happen only in case of Part Configuration.
So how to add uses tab under Structure tab.
A Product Configuration is created to determine which versions of items to use in a Product Instance. It is not meant for activities beyond this purpose and does not support editing of the BOM.
Is their any alternative to this?
What use case are you trying to solve?
I need BOM structure of Part Configuration Object .
Are their any API or any other way to get them?
The question is - what business use case are you trying to solve using a Part Configuration? As noted they are used to capture the versions for a Product Instance and not normally meant for other use cases.
Actually client to get information of change Request and uses of each part in the structure of Part Configuration. Since it is not possible to customize page, we decided to create a action for this. But , the problem we are facing is , how to display a tree structure table . No detail guide is available to do this.
It is unclear what you are trying to do here. Why would you want to have this on a Change Request?
