Is there a way to deselect a particular row from the tree selection?
I have a few selected rows in a table. But depending on an attribute of the selected row, I need to deselect it.
Example:
//All the selected rows are obtained in this these selections variable
var selections = tree.selModel.getSelections();
//The attribute "Should_not_be_Selected" represents the row which should be deselected.
for (var icount = 0; icount < selections.length; icount++) {
if (selections[icount].data.Should_not_be_Selected === "yes") {
//What should I do now with selections[icount] to deselect this row?
I couldn't find any help with TableUtils or TreeHandler.
Any idea?
PTC.jca.table.Utils.selectRow("changeNotice.changeSummary", "VR:wt.doc.WTDocument:617250438", false);
PTC.jca.table.Utils.selectRow(##tableID##, ##rowsObjectOID##, false);
Thanks very much @NT_10748259
That worked. One more favor do you have any link to these functions? I used to checked https://support.ptc.com/cs/help/windchill_hc but couldn't get these functions with the full arguments.
