Version: Windchill 12.0
Use Case: I need to fetch Task Comments for specific Wfprocess for CAPA or NC Objects, I have Object OID and WfProcess, currently I am trying to get info using following enpoint service however unable to see "Comments" value in the reponse \ Endpoint - > v5/CAPA/CAPAs('{CAPAId}')/WfProcess GET] v5/NC/Nonconformances('{NonconformanceId}')/WfProcess s Even tried using this expand query "WorkItem($expand=Owner)"
Description:
Need assistance with navigating to workItem TaskComments using above service endpoints
You might have to write your own service to access comments.
Hi @Rohaan
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
