I have created a wizard using attachments tags.
<attachments:fileSelectionAndUploadApplet/>
<attachments:primaryAttachment>
I am able to display browser option on wizard.
How to get that file on form Processor?
Did you ever solve this problem? If so, could please share the code?
I figured it out, but it's a little bit tricky and I'm not sure if I did it the right way, but it works.
This method is not finished, it's just an example to add an uploaded file as a primary of a WTDocument. If already a primary exists it need to be deleted first. So it will only work for a WTDocument with no file attached.
@Override
public FormResult doOperation(NmCommandBean nmCommandBean, List<ObjectBean> list) throws WTException {
FormResult formResult = new FormResult();
ObjectIdentifier oidObject = nmCommandBean.getElementOid().getOidObject();
WTDocument wtDocument = (WTDocument) PersistenceHelper.manager.refresh(oidObject);
try {
ContentHolder contentHolder = ContentHelper.service.getContents(wtDocument);
for (ObjectBean bean : list) {
log.debug("bean = \"{}\"", bean.getParameterMap());
Map<String, String> text = bean.getText();
String oid = null;
String filename = null;
String cachedContentDescriptorValue = null;
for (Map.Entry<String, String> entry : text.entrySet()) {
String key = entry.getKey();
log.debug("key = \"{}\"", key);
if (key.startsWith("PRIMARY_FILE") && key.endsWith("_cachedContentDescriptor")) {
oid = key.replace("PRIMARY_FILE_", "").replace("_cachedContentDescriptor", "");
log.debug("oid = \"{}\"", oid);
cachedContentDescriptorValue = entry.getValue();
log.debug("cachedContentDescriptorValue = \"{}\"", cachedContentDescriptorValue);
} else if (key.startsWith("PRIMARY_FILE") && key.endsWith("_filePath" )) {
filename = entry.getValue();
if (filename != null && oid != null && cachedContentDescriptorValue != null) {
ApplicationData applicationData = ApplicationData.newApplicationData((ContentHolder) null);
applicationData.setFileName(filename);
CachedContentDescriptor cachedContentDescriptor = new CachedContentDescriptor(cachedContentDescriptorValue);
applicationData.setRole(ContentRoleType.PRIMARY);
applicationData.setContentIdentity(cachedContentDescriptor.getContentIdentity());
ContentServerHelper.service.updateContent(contentHolder,applicationData,cachedContentDescriptor);
} catch (PropertyVetoException e) {
log.error("Error 155122:", e);
return formResult;
