I have a classification attribute named Colour with internal name COLOR,
in the Constraints tab, I have assigned global enumeration which is having internal name Colour(COLOR_ABC).
Is there any api available such that when I give an input of Classification Attribute internal name (COLOR), my output should fetch the global enumeration used COLOR_ABC.
If I do understand you correctly, you want the display value of the selected enumeration. This is found e.g. in the support case:
https://www.ptc.com/en/support/article/CS204076
Important is, that you always need to load the classification link attribute together with the needed attribute.
@BjoernRueegg , thanks for the reply.
This will work If you have a persistable object, but in my scenario, I know only the Internal Name of the classification attribute used, need to get the Internal Name of External Global enumeration used in the Constraint.
You need to check for the constraints of the attributes then filter on the constraint of type global enumeration
