Hi Gurus,
I am using Windchill 10.2 M030 CPS5, I need to get the list of attributes in a email notification of that particular PBO, There is a workflow associated to it. I need to send a mail to Users with List of Attributes in Email Body and Some Attributes in Subject As well.
Thanks in Advance
Best Regards,
Mahesh Kumar G
Mahesh,
I don’t know which POB you are using for workflow (Document Part Promotion Request or Change object).
Use below steps
However if it is Change object then i would sugest to create summary report (ECN / ECR ) in workflow using customer helper class and send it to user as an attachment see this link for sample
Hope it helps!!!
Shreyas
Hi Shreyas,
Thanks for your information. I am using WTDocument as PBO.
I will try the above CS Doc and let you know.
Thanks & Best Regards,
Mahesh
