How to get the List of pbo attributes in an Email Notification?
maheshkumar
2-Explorer
Hi Gurus,
I am using Windchill 10.2 M030 CPS5, I need to get the list of attributes in a email notification of that particular PBO, There is a workflow associated to it. I need to send a mail to Users with List of Attributes in Email Body and Some Attributes in Subject As well.
Thanks in Advance
Best Regards,
Mahesh Kumar G
Mahesh,
I don’t know which POB you are using for workflow (Document Part Promotion Request or Change object).
Use below steps
  1. Create workflow variable for example String colour;
  2. In expression robot get the value of colour attribute from PBO use PersistableAdapter API https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS135663
  3. Use color attribute in email robot. i.e. in subject and in body
However if it is Change object then i would sugest to create summary report (ECN / ECR ) in workflow using customer helper class and send it to user as an attachment  see this  link for sample
https://community.ptc.com/t5/Windchill/How-can-send-Email-attachments-through-code-with-API-wt-mail/m-p/23634#415295
Hope it helps!!!
Shreyas
Hi Shreyas,
Thanks for your information. I am using WTDocument as PBO.
I will try the above CS Doc and let you know.
Thanks & Best Regards,
Mahesh
