I am trying to get the numerical value of the Structure Level of a part in a mulitlevel BOM via Windchill REST Services, similiar to when exporting a Multi-Level BOM of Material Report under an assemblies structure tab.
The GetPartStructure endpoint doesnt seem to have an attribute specifically for Structure Level. Is there another endpoint or a maybe a param I may be missing?
Hi @mariaSutton
Structure level is always counted during the generation. so attribute level does not exists in database
You need to calculate the level from the assembly you are standing on. .
PetrH
Hi @mariaSutton,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
