How to get the view of the WTPart in workflow ?
K_Patil
11-Garnet
I want to get the view of the WTPart in workflow to compare if it is "Design" or "manufacturing".
I used below code in workflow execute expression robot.
if (primaryBusinessObject instanceof wt.part.WTPart) {
    wt.part.WTPart part = (wt.part.WTPart) primaryBusinessObject;
    wt.vc.views.View view = (wt.vc.views.View) part.getView().getObject();
if(view != null && view.equals("Design")){
result = "Go";
}else{
result = "NoGo";
On syntax check it work,
However, if i add workflow variable i got below error on syntax check.
Checking Syntax...
warning: Supported source version 'RELEASE_7' from annotation processor 'com.microsoft.azure.management.apigeneration.LangDefinitionProcessor' less than -source '1.8'
WfExpression_1315495121.java:129: error: variable view is already defined in method executemethod_1(Object[],Object[])
Note: WfExpression_1315495121.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
1 error
1 warning
Syntax check complete.
Can someone please guide me ?
HelesicPetr
(To:K_Patil)
Hi @K_Patil
What Windchill version do you use?
btw, where the variable partName is defined?
Do you define this variable in the workflow variable? if so, then you can not define it again in your code.
If I create global workflow variable, then I get same error as you.
if the variable is defined as a global then you can not define it again.
instead of wt.vc.views.View partName = ........
use just partName = (wt.vc.views.View) part.getView().getObject();
PetrH
HelesicPetr
(To:K_Patil)
Hi @K_Patil
Check the name of variable, it can not be same as the defined object wt.vc.views.View view
the error tells you that you have two declarations of the same variable and it can not be used.
PS> the view variable is a object type wt.vc.views.View so you can not compare the vale to a string "Design" that way as you try.
you can compare two strings not String with wt.vc.views.View. Try to use view.getName();
PetrH
Hi @HelesicPetr ,
I tried to adopt it, but it is still the same.
wt.vc.views.View partName = (wt.vc.views.View) part.getView().getObject();
if (partName != null && "Design".equals(partName.getName())) {
result = "Go";
} else {
result = "NoGo";
Checking Syntax...
WfExpression_1315495121.java:129: error: variable partName is already defined in method executemethod_1(Object[],Object[])
1 error
1 warning
can you please check ?
HelesicPetr
(To:K_Patil)
Hi @K_Patil
PetrH
Hi @HelesicPetr ,
Thank you so much, resolved the issue.
avillanueva
23-Emerald I
(To:K_Patil)
Great job @HelesicPetr
