How to handle master object creation while creating multiple versions of an object
  • March 27, 2024
  • 2 replies
  • 2764 views
I have a scenario,
consider I am creating the following objects using Windchill Custom API loader.
EPMDocument -
xyz.prt, versions A.1,B.1,C.1
WTPart -
abc, versions A.1,B.1,C.1
I use the below static methods to initialize the objects.
EPMDocument.newEPMDocument(docNumber, docName, authoringApp, docType, cadName) for epmdocument
WTPart.newWTPart(number,name) for wtpart
My question:
First, when A.1 instance is created, i believe the API also creates its master object in the background.
What happens when i move to B.1 creation, with same API code?
will it attempt re-creation of master object (or)override  existing master object during B.1 and C.1?
Best answer by Fadel
@NP_10570407  try something like below to create a cad in a given version  :
ObjectIdentifier oid = ObjectIdentifier.newObjectIdentifier("wt.epm.EPMDocument:169864");
EPMDocument epm = (EPMDocument) PersistenceHelper.manager.refresh(oid);
String version = "D";
MultilevelSeries mls = MultilevelSeries.newMultilevelSeries("wt.vc.VersionIdentifier", version);
VersionIdentifier vid = VersionIdentifier.newVersionIdentifier(mls);
WTKeyedHashMap rev_map = new WTKeyedHashMap();
ReviseOptions rev_opts = new ReviseOptions(epm);
// comment the line below if you want to use the next revision in the serie
rev_opts.document.versionId = vid;
rev_map.put( epm, rev_opts);
EPMDocumentHelper.service.reviseAll(rev_map);
HelesicPetr
Hi @NP_10570407
I would say test it, you will see.
Please can you also share the result of your test? That we can discus it.
PetrH
PetrH
Hi @HelesicPetr ,
I have tested and end up with uniqueness exception as mentioned by @Fadel
Fadel
23-Emerald I
March 28, 2024
I would join Petr to test it , theoretically I would expect that you get
wt.pom.UniquenessException: EPMDocument - xxxx is not unique
Buiꓘa
HelesicPetr
@Fadel
And thanks that @NP_10570407 needs to find another way how to store new version to the system.
For example create a new revision on the existing object, with correct revision label etc.
PetrH
PetrH
Fadel
Fadel23-Emerald IAnswer
23-Emerald I
March 28, 2024
Buiꓘa
