How to handle master object creation while creating multiple versions of an object
NP_10570407
I have a scenario,
consider I am creating the following objects using Windchill Custom API loader.
EPMDocument -
xyz.prt, versions A.1,B.1,C.1
WTPart -
abc, versions A.1,B.1,C.1
I use the below static methods to initialize the objects.
EPMDocument.newEPMDocument(docNumber, docName, authoringApp, docType, cadName) for epmdocument
WTPart.newWTPart(number,name) for wtpart
My question:
First, when A.1 instance is created, i believe the API also creates its master object in the background.
What happens when i move to B.1 creation, with same API code?
will it attempt re-creation of master object (or)override  existing master object during B.1 and C.1?
Fadel
23-Emerald I
(To:HelesicPetr)
@NP_10570407  try something like below to create a cad in a given version  :
ObjectIdentifier oid = ObjectIdentifier.newObjectIdentifier("wt.epm.EPMDocument:169864");
EPMDocument epm = (EPMDocument) PersistenceHelper.manager.refresh(oid);
String version = "D";
MultilevelSeries mls = MultilevelSeries.newMultilevelSeries("wt.vc.VersionIdentifier", version);
VersionIdentifier vid = VersionIdentifier.newVersionIdentifier(mls);
WTKeyedHashMap rev_map = new WTKeyedHashMap();
ReviseOptions rev_opts = new ReviseOptions(epm);
// comment the line below if you want to use the next revision in the serie
rev_opts.document.versionId = vid;
rev_map.put( epm, rev_opts);
EPMDocumentHelper.service.reviseAll(rev_map);
Fede
9 REPLIES 9
HelesicPetr
(To:NP_10570407)
Hi @NP_10570407
I would say test it, you will see.
Please can you also share the result of your test? That we can discus it.
PetrH
Hi @HelesicPetr ,
I have tested and end up with uniqueness exception as mentioned by @Fadel
Fadel
23-Emerald I
(To:NP_10570407)
I would join Petr to test it , theoretically I would expect that you get
wt.pom.UniquenessException: EPMDocument - xxxx is not unique
Fede
HelesicPetr
(To:Fadel)
@Fadel
And thanks that @NP_10570407 needs to find another way how to store new version to the system.
For example create a new revision on the existing object, with correct revision label etc.
PetrH
Fadel
23-Emerald I
(To:HelesicPetr)
Fede
NP_10570407
(To:Fadel)
@Fadel  Thanks for sharing the code snippet. my scenario is different. I have to bulk load(create) objects based on input csv file. csv can have entries for more revisions/versions of same object. my method code below(sorry for long thread):
public EPMDocument createNewEPMDocument(String number,String version,HashMap<String,String> paramHashMap) throws WTException {
        String str1 = CLASSNAME + ".createNewDocument: ";
        System.out.println("Entering... " + str1);
        EPMDocument localEPMDocument = null;
        try {
            String strName = paramHashMap.get("NAME");
            String strObjNumber = number;
            String desc = paramHashMap.get("DESCRIPTION");
            String c_org_name = paramHashMap.get("CONTAINER_ORGANIZATION_NAME");
            String cont = paramHashMap.get("CONTAINER");
            String c_type = paramHashMap.get("CONTAINERTYPE");
            String strEPMAuthtype = paramHashMap.get("AUTHORINGAPPTYPE"); ////e.g. value is 'PROE'
            String strEPMApptype = paramHashMap.get("EPMAPPLICATIONTYPE"); //e.g. value is 'EPM'
            String strEPMDoctype = paramHashMap.get("EPMDOCTYPE"); // e.g. value is 'CADCOMPONENT'
            String strCADName = paramHashMap.get("CADNAME");
            String strSeries = paramHashMap.get("SERIES");
            String strTypedef = paramHashMap.get("TYPEDEF");
            String[] res = version.split("[.]", 0);
            System.out.println("rev>"+res[0]);
            System.out.println("iter>"+res[1]);
            String strRevision = res[0];
            String strIteration = res[1];
            String strFolderPath = paramHashMap.get("FOLDERPATH");
            String strLCTemplate = paramHashMap.get("LIFECYCLETEMPLATE");
            String strState = paramHashMap.get("STATE");
            String strCreator = paramHashMap.get("CREATOR");
            String strModifier = paramHashMap.get("MODIFIER");
           // String tempNo = "";
            EPMAuthoringAppType localEPMAuthoringAppType = EPMAuthoringAppType
                    .toEPMAuthoringAppType(strEPMAuthtype);
            EPMApplicationType localEPMApplicationType = EPMApplicationType
                    .toEPMApplicationType(strEPMApptype);
            EPMDocumentType localEPMDocumentType = EPMDocumentType.toEPMDocumentType(strEPMDoctype);
            EPMContextHelper.setApplication(localEPMApplicationType);
            localEPMDocument = EPMDocument.newEPMDocument();
            TypeIdentifier ti = TypeHelper.getTypeIdentifier(strTypedef);
            WCTypeIdentifier wti = (WCTypeIdentifier) ti;
            TypeDefinitionReference tdr = TypedUtility.getTypeDefinitionReference(wti.getTypename());
            localEPMDocument.setTypeDefinitionReference(tdr);
            localEPMDocument.setName(strName);
            localEPMDocument.setNumber(strObjNumber);
            EPMDocumentMaster localEPMDocumentMaster = (EPMDocumentMaster) localEPMDocument.getMaster();
            localEPMDocumentMaster.setSeries(strSeries);
            if (localEPMDocumentMaster != null) {
                if (localEPMDocumentMaster.getDocType() != null) {
                    localEPMDocument.setDocType(localEPMDocumentMaster.getDocType());
                } else {
                    localEPMDocumentMaster.setDocType(localEPMDocumentType);
                if (localEPMDocumentMaster.getOwnerApplication() == null) {
                    localEPMDocumentMaster.setOwnerApplication(localEPMApplicationType);
                if (localEPMDocumentMaster.getAuthoringApplication() == null) {
                    localEPMDocumentMaster.setAuthoringApplication(localEPMAuthoringAppType);
                if (strCADName != null) {
                    localEPMDocumentMaster.setCADName(strCADName);
                } else {
            } else {
            System.out.println("createNewEPMDocument EPMDocNumber: " + strObjNumber
                        + "   ===> Master is null. Error Setting EPMDocumentMaster!!");
                return null;
            localEPMDocumentMaster.setDocSubType(EPMDocSubType.getEPMDocSubTypeDefault());
            localEPMDocument.setContainer(CommonUtilities.getContainer(cont));
            if (desc != null) {
                localEPMDocument.setDescription(desc);
            WTOrganization localWTOrganization = CommonUtilities.getWTOrganizationByName(c_org_name);
            if (localWTOrganization == null) {
                throw new WTException("Organization \"" + c_org_name + "\" does not exist.");
            localEPMDocument.setOrganization(localWTOrganization);
            System.out.println("Setting the Version and Iteration");
            //System.out.println("Setting Type for EPMDocument...");
           // localEPMDocument = (EPMDocument) setType(paramHashtable, localEPMDocument);
            MultilevelSeries mls = MultilevelSeries.newMultilevelSeries("wt.vc.VersionIdentifier", strRevision);
VersionIdentifier versionId = VersionIdentifier.newVersionIdentifier(mls);
            VersionControlHelper.setVersionIdentifier((Versioned)localEPMDocument, versionId);
            // set folder
            Folder folder = FolderHelper.service.getFolder(strFolderPath,
                    WTContainerRef.newWTContainerRef(CommonUtilities.getContainer(cont)));
            FolderHelper.assignFolder(localEPMDocument, folder);
            //FolderHelper.assignLocation(localEPMDocument, localFolder); ANOTHER API TO SET FOLDER
            // set lifecycle
            LifeCycleTemplate lct = LifeCycleHelper.service.getLifeCycleTemplate(strLCTemplate,
            LifeCycleHelper.setLifeCycle(localEPMDocument, lct);
            localEPMDocument = (EPMDocument) LifeCycleServerHelper.setState(localEPMDocument, State.toState(strState));
            CommonUtilities.setCreator((Iterated)localEPMDocument,strCreator);
            CommonUtilities.setModifier((Iterated)localEPMDocument,strModifier);
          /*  TypeInstanceIdentifier localTypeInstanceIdentifier = TypeIdentifierUtility
                    .getTypeInstanceIdentifier(localEPMDocument);
            TypeInstance localTypeInstance = TypeInstanceFactory.newTypeInstance(localTypeInstanceIdentifier);
            TypeInstanceUtility.populateMissingTypeContent(localTypeInstance, null);*/
            localEPMDocument.setPlaceHolder(false);
            localEPMDocument = (EPMDocument) PersistenceHelper.manager.store(localEPMDocument);
            Series ser = Series.newSeries("wt.vc.IterationIdentifier", strIteration);
            IterationIdentifier iterationId = IterationIdentifier.newIterationIdentifier(ser);
            VersionControlHelper.setIterationIdentifier((Iterated)localEPMDocument, iterationId);
            System.out.println("Exiting... " + str1);
        } catch (NoSuchElementException localNoSuchElementException) {
        System.out.println(localNoSuchElementException);
            throw new WTException(localNoSuchElementException.getMessage());
        } catch (WTPropertyVetoException localWTPropertyVetoException) {
        System.out.println(localWTPropertyVetoException);
            throw new WTException(localWTPropertyVetoException.getMessage());
        return localEPMDocument;
HelesicPetr
(To:NP_10570407)
Hi @NP_10570407
So if you load more revisions you have two options
First load all data from CSV and then check if there are different revisions and work with it.
Second you can react to the exception and try to revise the existing object to the revision you need by code and set the attributes from your CSV as you need.
PetrH
Thanks a ton to both @HelesicPetr and @Fadel for your valuable inputs. it helped me to resolve the uniqueness error.
You guys are great.
@HelesicPetr & @Fadel
My loader read the input values from a csv file and create the epmdocuments accordingly.
In csv file, i have entries to create two revisions of same object back to back. for e.g.,
A.1 created successfully, while creating the same B.1 using same API, it fails with uniqueness
