I found the related article "https://www.ptc.com/en/support/article/CS370997?source=search" and can be made the "Task comments" as mandatory. Thank you all for your responses.
Is there an error when completing the task or can you complete the task without commenting. Clearing the browser history/cache fixed this one for me.
No error message, it simply complete the task.
have you tried the validateCommentsAlternative from same article
Yes, but still the same issue, no alert message.
