How to make a policy result in an error when an API is executed by an administrator
SI_10934165
3-Newcomer
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M010
Using the API of "SessionHelper.manager.setAdministrator", you can use "wt.vc.wip.WorkInProgressHelper.service.undoCheckout", "ChangeHelper2.service.unattachChangeable", " VersionControlHelper.service.deleteIterations" API is executed, \nI would like to get an error if I set the permission to "Deny" in policy management, but it does not result in an error. \nCan I change the policy management so that it fails?
Translated text from Japanese to English using PTC translate tool
Body: SessionHelper.manager.setAdministrator」のAPIを使い管理者にて、「wt.vc.wip.WorkInProgressHelper.service.undoCheckout」「ChangeHelper2.service.unattachChangeable」、「VersionControlHelper.service.deleteIterations」のAPIを実行させた際に、
ポリシー管理で権限を「拒否」にすればエラーとなるようにしたいのですが、エラーになりません。
ポリシー管理を変更して、エラーにする方法をできますか?
--By Community Moderation Team
HelesicPetr
(To:SI_10934165)
Hi @SI_10934165
Some methods check the ACL some not.
If you write onw code, then you should check if the user has a permission and stop the operation . Does not matter if he is admin or not.
It applies also for the session where is Administrator set by method setAdministrator.
PetrH
2 REPLIES 2
HelesicPetr
(To:SI_10934165)
Hi @SI_10934165
PetrH
Hello @SI_10934165
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
