How to make ready only "Name & Number" attributes on Part Edit Common Attribute Page
WT_010219
Version: Windchill 12.1
Use Case: I want make ready only "Name & Number" attributes on Part Edit Common Attribute Page :
Description:
I am unable to figure if I should use data utility or Validator for this.
1. I tried data utility but I didn't triggered as I am able to registered data utility ID since there is no such Edit Common Attribute layout.
public class DisableName extends DefaultDataUtility {
	protected static final Logger logger = LogR.getLogger(DisableName.class.getName());
	@Override
	public UIValidationStatus getDataValue(String filedName, Object object, ModelContext modelContext)
			throws WTException {
		System.out.println("---- DisableName on Part CommonAttribute Started-------------");
		UIValidationStatus status = UIValidationStatus.ENABLED;
		System.out.println("---- filedName :" + filedName);
		if (modelContext.getDescriptorMode().equals(ComponentMode.EDIT)) {
			if (filedName.equalsIgnoreCase("name")|| filedName.equalsIgnoreCase("number") ) {
				System.out.println("---- filedName available ");
				status = UIValidationStatus.ATTR_HIDDEN_VALUE;
		System.out.println("---- returning status : " + status);
		return status;
2. I tried extending EditPartCommonAttrsActionValidator and used preValidateAttribute, but It also didn't got triggered..
public class PartEditCommonAttributeValidator extends EditPartCommonAttrsActionValidator {
	@Override
	public UIValidationStatus preValidateAttribute(UIValidationKey var1, UIValidationCriteria var2) {
		UIValidationStatus status = super.preValidateAttribute(var1, var2);
		System.out.println("---- PartEditCommonAttributeValidator Validator Started-------------");
		Persistable launchedFrom = var2.getContextObject().getObject();
		System.out.println("launchedFrom" + launchedFrom);
		System.out.println("validationKey : " + var1);
		System.out.println("---- Validator Status : " + status);
		return status;
Can you please help to get correct methodology to implement my requirement.
Thank you in advance.
There are some ACLs that may apply here. See: https://www.ptc.com/en/support/article/CS23471?source=search
Thank you @joe_morton  , I will check
Fadel
23-Emerald I
(To:WT_010219)
You can do tha Oo TB t from UI :
In type and attribute manager find these attributes on WTPartMaster and set visibility to read only on edit  :
Fede
WT_010219
(To:Fadel)
Thank you @Fadel
I works for other attribute as you show but not foe name & number. I want to do it for name & number.
Thanks you.
