Hi there,
I'm trying to obtain the options from a saved filter. "Choices"
try {
java.lang.String username = "testuser";
wt.session.SessionHelper.manager.setPrincipal(username);
wt.filter.NavigationCriteria navigationCriteria = wt.filter.NavigationCriteriaHelper.service.getNavigationCriteria("MyFilter");
if (navigationCriteria == null) {
java.lang.System.out.println("Filter 'MyFilter' not found or user does not have access.");
} else {
java.lang.System.out.println("Navigation Criteria Name: " + navigationCriteria.toString());
java.util.List<wt.filter.NavigationFilter2> filters = (java.util.List<wt.filter.NavigationFilter2>)navigationCriteria.getFilters();
if (filters == null || filters.isEmpty()) {
java.lang.System.out.println("No filters found for the Navigation Criteria.");
} else {
for (wt.filter.NavigationFilter2 filter : filters) {
java.lang.System.out.println("Filter Name: " + filter.toString());
java.lang.System.out.println("Filter Type: " + filter.getType());
} catch (java.lang.Exception e) {
java.lang.System.out.println("Error switching session: " + e.getMessage());
} finally {
java.lang.System.out.println("Process completed.");
}Here my logs:
Navigation Criteria Name: wt.filter.NavigationCriteria:xxxxxx Filter Name: com.ptc.windchill.option.model.ATONavigationFilter:xxxxxx Filter Type: ATONavigation Filter Process completed.
I think I'm sucessfully obtain the filter but i can't reach the Choices from this type. I need to parse the Choices.
Also i'm trying to get it from NavigationFilter2, i've found a javadoc for this i think i can parse it from the json if i call "getJSONFromFilter(NavigationFilter2 navFilter)" getJSONFromFilter function.
So i've used code like that;
(java.util.List<wt.filter.NavigationFilter2>) navigationCriteria.getFilters();
for (wt.filter.NavigationFilter2 navFilter : filters) {
String jsonRepresentation = wt.filter.NavigationFilterDelegate2.getJSONFromFilter(navFilter);
System.out.println(jsonRepresentation);
}But i couldn't compile this code because NavigationFilterDelegate2 is an interface so i can't call it directly.
@HelesicPetr i wonder your comment for second part too 🙂
Hi @Anil_SAD
If the Filter contains the Options then it should be an ATONavigationFilter type.
So retype the filter to the mentioned type and use the get methods for the options set and choice map
It works. btw if you are not sure if the user has an access to the saved filter, then change the active user to an Administrator for the time.
NavigationCriteria crit = NavigationCriteriaHelper.service.getNavigationCriteria("MYVARIANT", true);
System.out.println(crit.toString());
Collection<NavigationFilter2> filters = crit.getFilters();
for (NavigationFilter2 navigationFilter2 : filters)
if (navigationFilter2 instanceof ATONavigationFilter)
ATONavigationFilter atonFilter = (ATONavigationFilter) navigationFilter2;
System.out.println(atonFilter.getOptionSet().toString());
System.out.println(atonFilter.getFilterType());
System.out.println(atonFilter.getChoiceMap().toString());
my output
PetrH
Hi @Anil_SAD
Thank you for your question!
Best regards,
Hi @Anil_SAD
my output
PetrH
Thank you @HelesicPetr , i've finally succesfully done it. I'm able to obtain all choice names by this code 🙂
try {
// Set Active user
// Get Filter
} else {
java.util.List<wt.filter.NavigationFilter2> filters = (java.util.List<wt.filter.NavigationFilter2>) navigationCriteria.getFilters();
StringBuilder choiceNames = new StringBuilder();
for (wt.filter.NavigationFilter2 navigationFilter2 : filters) {
if (navigationFilter2 instanceof com.ptc.windchill.option.model.ATONavigationFilter) {
com.ptc.windchill.option.model.ATONavigationFilter atonFilter = (com.ptc.windchill.option.model.ATONavigationFilter) navigationFilter2;
System.out.println("OptionSet: " + atonFilter.getOptionSet().toString());
System.out.println("FilterType: " + atonFilter.getFilterType());
java.util.Map<?, ?> choiceMap = atonFilter.getChoiceMap();
for (Object optionObj : choiceMap.keySet()) {
Object choicesObj = choiceMap.get(optionObj);
if (choicesObj instanceof java.util.Set) {
java.util.Set<?> choicesSet = (java.util.Set<?>) choicesObj;
for (Object choiceObj : choicesSet) {
long choiceId = Long.parseLong(choiceObj.toString().split(":")[1]);
wt.fc.ReferenceFactory rf = new wt.fc.ReferenceFactory();
com.ptc.windchill.option.model.Choice choiceFromRef = (com.ptc.windchill.option.model.Choice) rf.getReference("com.ptc.windchill.option.model.Choice:" + choiceId).getObject();
if (choiceFromRef != null) {
if (choiceNames.length() > 0) {
choiceNames.append(", ");
choiceNames.append(choiceFromRef.getName());
} else {
System.out.println("Choice with ID " + choiceId + " not found.");
System.out.println("Choice Names: " + choiceNames.toString());
} else {
System.out.println("No choices found.");
} finally {
