Hi All,
I am trying to create a WTPart from java. In my set up the classification is set as a mandatory attribute.
Could you please help me on how to set the value of the primary classification? I tried to set the default value for the classfication, however it does not work. Here is the code I am using to create WTPart.
WTPart wtpart=WTPart.newWTPart();
try {
TypeIdentifier typeidentifier = TypeHelper.getTypeIdentifier("WCTYPE|wt.part.WTPart");
WCTypeIdentifier wctypeidentifier = (WCTypeIdentifier) typeidentifier;
TypeDefinitionReference typeDefinitionReference = TypedUtilityServiceHelper.service.getTypeDefinitionReference(wctypeidentifier.getTypename());
wtpart.setTypeDefinitionReference(typeDefinitionReference);
wtpart.setName("Test part007");
String container_path = "/wt.inf.container.OrgContainer=yyyy/wt.pdmlink.PDMLinkProduct=xxxx";
WTContainerRef containerRef = WTContainerHelper.service .getByPath(container_path);
wtpart.setContainerReference(containerRef);
String folder_path = "/Default";
Folder folder = FolderHelper.service .getFolder(folder_path,containerRef);
FolderHelper. assignLocation(wtpart, folder);
wtpart=(WTPart) wt.fc.PersistenceHelper.manager .store(wtpart);
Thanks in advance.
Hi @jselvaraj,
Have you tried "How to set classification node or classification attributes value (available for 10.2 M030 and 11.0)" section of KB article CS217792?
WTPart part_work = (WTPart)WorkInProgressHelper.service.checkout(part, WorkInProgressHelper.service.getCheckoutFolder(), null).getWorkingCopy(); PersistableAdapter obj = new PersistableAdapter(part_work,null,SessionHelper.getLocale(), new UpdateOperationIdentifier()); obj.load(bindingAttributeName); obj.set(bindingAttributeName,classificationNode); obj.apply(); PersistenceHelper.manager.modify(part_work); return (WTPart)WorkInProgressHelper.service.checkin(part_work, null);
Are you having some trouble doing it?
Shirish
I agree to use PersistableAdapter class to set the classification attribute value.
Hi selvaraj,
could you please provide me a import statement for TypeHelper.getTypeIdentifier();
It would me more helpful for me.
