How to test the code to check the type of WTObject
ChiselnMallet1
As per this thread - same question:
@CHASEONHO did you get this part figured out... I'm fairly new to all this... I have my eclipse environment configured (I beleive)  but have yet to figure out how to test code from it.
Are you asking how to setup Eclipse with Windchill or how to test checking the object type code portion?
My Eclipse environment is set up... I want to be able to run my code on an object and get system outs in the console so I can rapidly iterate the code with out having to plug it into my expression robot and create new PR objects to test.
Hi @ChiselnMallet1
You have several options how to run your code.
From Windchill shell call a java class (windchill wt.load.util.UpdateEditDTDUtility)
From WebBrowser to call  a java class with RemoteAccess (http://server.my.com/Windchill/servlet/WindchillAuthGW/com.ex.JavaPackange/MyMethod)
or create button in windchill to call a java class method
PS: very useful is a Customization Guide
PetrH
