As per the title, how do you update string iba values without iterating.
I know this is possible but cant seem to find the code to do so at the moment.
Hi @NT_10748259
Check this thread Java Code to add Windchill IBA Values to WTPart Object
There is a code for the update
public static Persistable updateIBAValue (IBAHolder ibaHolder, String ibaName, Object ibaValue)
throws RemoteException, WTException, WTPropertyVetoException
logger.debug("...Inside updateIBAValue...");
ibaHolder = IBAValueHelper.service.refreshAttributeContainer(ibaHolder, null, null, null);
StandardIBADefinitionService defService = new StandardIBADefinitionService();
DefaultAttributeContainer attributeContainer = (DefaultAttributeContainer) ibaHolder.getAttributeContainer();
AttributeDefDefaultView attributeDefinition = defService.getAttributeDefDefaultViewByPath(ibaName);
AbstractContextualValueDefaultView attrValue = null;
AbstractValueView abstractValueView[] = attributeContainer.getAttributeValues(attributeDefinition);
logger.debug("abstractValueView.length..." + abstractValueView.length);
if ((abstractValueView.length == 0))
{ // No existing value, needs to be created if approvedDate argument has a value
if (null != ibaValue)
if (attributeDefinition instanceof TimestampDefView && ibaValue instanceof Timestamp)
logger.debug("attributeDefinition is TimestampDefView...");
attrValue = new TimestampValueDefaultView((TimestampDefView) attributeDefinition,
(Timestamp) ibaValue);
} else if (attributeDefinition instanceof StringDefView)
logger.debug("attributeDefinition is StringDefView...");
attrValue = new StringValueDefaultView((StringDefView) attributeDefinition, ibaValue.toString());
} else if (attributeDefinition instanceof FloatDefView)
logger.debug("attributeDefinition is FloatDefView...");
if (ibaValue instanceof FloatingPoint)
logger.debug("ibaValue is FloatingPoint..." + ibaValue);
ibaValue = ((FloatingPoint) ibaValue).getValue();
logger.debug("ibaValue..." + ibaValue);
attrValue = new FloatValueDefaultView((FloatDefView) attributeDefinition, (Double) ibaValue, 5);
} else if (attributeDefinition instanceof IntegerDefView)
logger.debug("attributeDefinition is IntegerDefView...");
attrValue = new IntegerValueDefaultView((IntegerDefView) attributeDefinition, (Long) ibaValue);
attributeContainer.addAttributeValue(attrValue);
} else
System.out.println("ibaValue is null...");
return (Persistable) ibaHolder;
} else
{ // Has existing value, needs to be updated/resetted
AbstractValueView avv = abstractValueView[0];
if (null == ibaValue)
{// Reset case
attributeContainer.deleteAttributeValue(avv);
} else
{ // Update case
logger.debug("Update Case...");
if (avv instanceof TimestampValueDefaultView)
logger.debug("avv is TimestampValueDefaultView...");
((TimestampValueDefaultView) avv).setValue((Timestamp) ibaValue);
} else if (avv instanceof StringValueDefaultView)
logger.debug("avv is StringValueDefaultView...");
((StringValueDefaultView) avv).setValue(ibaValue.toString());
} else if (avv instanceof FloatValueDefaultView)
logger.debug("avv is FloatValueDefaultView...");
logger.debug("ibaValue is FloatingPoint for Update case..." + ibaValue);
((FloatValueDefaultView) avv).setValue((Double) ibaValue);
} else if (avv instanceof IntegerValueDefaultView)
logger.debug("avv is IntegerValueDefaultView...");
((IntegerValueDefaultView) avv).setValue((Long) ibaValue);
attributeContainer.updateAttributeValue(avv);
ibaHolder.setAttributeContainer(attributeContainer);
StandardIBAValueService.theIBAValueDBService.updateAttributeContainer(ibaHolder, null, null, null);
WTCollection byPassIterationModifierSet = new WTHashSet();
byPassIterationModifierSet.add(ibaHolder);
WorkInProgressServerHelper.putInTxMapForValidateModifiable(byPassIterationModifierSet);
Persistable persObject = PersistenceHelper.manager.save((Persistable) ibaHolder);
// PersistenceServerHelper.manager.insert((Persistable)ibaHolder);
return persObject;
PetrH
Hi @NT_10748259
} else
} else
{// Reset case
} else
{ // Update case
return persObject;
PetrH
Hi there,
I had a similar issue, where I tried to change an IBA - Value during a promotion request process.
Thanks to the discussion here, i was able to solve it.
I posted the whole procedure here:
https://community.ptc.com/t5/Windchill-Customization/Info-How-to-set-attribute-for-quot-released-by-quot-quot/m-p/988177
