How to use the java api to add WTDocument to the "Change Summary" table in Change Notice?
VladiSlav
I have code to output "Change Summary" object types from a Change Notice
But I do not know how to add more objects to this table, for example, WTDocument
public static void printChangeAfter(WTChangeOrder2 wtChangeOrder2) {
        try {
            QueryResult result = ChangeHelper2.service.getChangeActivities(wtChangeOrder2);
            while (result.hasMoreElements()) {
                WTChangeActivity2 activity = (WTChangeActivity2) result.nextElement();
                QueryResult res = ChangeHelper2.service.getChangeablesAfter(activity);
                while (res.hasMoreElements()) {
                    WTObject object = (WTObject) res.nextElement();
                    System.out.println(object.getType());
        } catch (WTException e) {
            System.out.println("error " + e.getMessage());
You can't add any object to the change summary table. This is just the summary of all the change tasks (change activities). You need to add them to a single change task
Vector partVec = new Vector();
partVec.addElement(part); //assuming you have the WTPart object
partVec = ChangeHelper2.service.storeAssociations(ChangeRecord2.class, task, partVec); //task is Change Activity object
ChangeRecord2 resulting_data = (ChangeRecord2)partVec.firstElement();
resulting_data.setDescription("ChangeRecord2 and a Part");
partVec = ChangeHelper2.service.saveChangeRecord(partVec);
 See https://www.ptc.com/en/support/article/CS122930 or https://www.ptc.com/en/support/article/CS200677
6 REPLIES 6
WM_9965332
(To:VladiSlav)
You can use instanceof to know if object is WTDocument, WTPart etc
if(object instanceof WTDocument){
WTDocument doc = (WTDocument)Object;
BjoernRueegg ,thank you very much, your code works as I wanted
BjoernRueegg ,please tell me if you have a code to remove objects from the request
You need find the link and delete the link.
Use the Helper class
and than the method you need. If you use the method e.g.
ChangeHelper2.service.getChangeablesAfter(changenotice, false);
then you will receive the links and not the objects. Iterate thru the result and delete the link you don't need anymore.
