Howto get Engineering sequence of newly added customer parts
AP_10343008
Version: Windchill 12.0
Use Case: fetching wrs data from navigate
Description:
In Master BOM in windchill, Customer have added new type of parts and its engineering sequence in new column. Iam getting those new parts in getPartStructure API. But i want the new column 'engineering sequence' data for new parts. How to fetch it using WRS API.
Hi @AP_10343008,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
I got Engineering Sequence data from Part Usage links.
Thanks.
HelesicPetr
(To:AP_10343008)
Hi @AP_10343008
And can you describe(share) the syntax what have you used? that it can be used as a Solution?
PetrH
