I need to retrieve all the parts from library whose part number start from 9 & update IBA attribute.
RR_13300108
Library name: Standard Part Manager
these 3 IBA values need to update
IBA attribute 1: Source - Buy
IBA attribute 2: Assembly mode - Component
IBA attribute 3: Part category - Fastener
Fadel
22-Sapphire III
(To:RR_13300108)
easiest way is to run a search and use edit multiple objects :
select all objects and use edit attribute value :
Fede
RR_13300108
(To:Fadel)
Hi @Fadel
Thank you for your response.
But i need to retrieve this through customization, ok found one article I completed it.
@RR_13300108,
So did you solve your own problem? What was the article that you found that was helpful? Please post,
Hello @RR_13300108,
It looks like you have a response from a PTC support expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
