Implement PDMLink option veryfying check in of unverified family tables
mkorycki
Implement the PDMLink options, which enables to choose if unverified family table can be checked in or not. Currently we have to invest additional effort to create specific triggers / listeners, which can prevent check in unverified family tables. Options available in Creo:
    • Modelcheck
    • Die config.pro option: verify_on_save_by_default=yes
are not sufficient. We need the option in PDMlink. Now in PDMlink 10.2 or 11.0 it's possible to check in the unverified family table.
2 REPLIES 2
BenLoosli
(To:mkorycki)
If check-in is possible with the config.pro option set to verify on save, then this is a bug and should be reported as such.
mkorycki
(To:mkorycki)
If you set the "verify_on_save_by_default=yes" you get the warning message. You have the choice to verify the family table, to ignore or always ignore. If the option "always ignore"  is chosen  no warning message is displayed by next attempt although the option is set to "yes". We are looking for the option in PDMlink, which prevents checking in unverified family table.
