Info-Engine Query-Tree webject
DhanshriTelang
7-Bedrock
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.15
unable to fetch usagelink attribute using element.getValue("quantity.unit") in info-engine task. Using Query-Tree webject.
Here are the errors that I faced
It's simply returning null value while in info-engine output value is shown.
Hi @HelesicPetr,
below line of code worked to fetch usage link quantity-
element.getValue("wt.part.WTPartUsageLink.quantity.amount")
Hi @DhanshriTelang
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Have you confirmed that the attribute is exposed and accessible in the Info-Engine mapping configuration?
  • Are you using the correct element reference and path in the script (e.g., nested elements)?
  • Have you tried accessing the attribute using an alternative key or checking case sensitivity?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Resolved.. thank you
Hi @DhanshriTelang
Could you describe your solution?
PetrH
Hi @HelesicPetr,
