When doing a Classification Manager export of parts link, it does not include any Instantiable data. Instantiable column is not coming in export sheet. The exportable sheet should also include the Instantaible property.
Hi @SM_11016017
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Are you referring to this field?
If you are not seeing that or if its not being imported in, I recommend submitting an idea for enhancement to PTC. I get that this might be a PITA when syncing structures but should be easy enough to manually walk the tree and have match up.
Yes I am referring this field only. when I am doing whole classification import, this field is not coming in the exportable sheet.
