Introduce a new tab in WTDocument Page
Sha11
I want to introduce a new tab under a specific type of WTDocument page and populate it with some of the attributes, could you shed some light on how to approach this requirement?
Sha
HelesicPetr
(To:HelesicPetr)
I forgot mention very important point.
You should create own Validation class where you check if the action should be shown in the detailpage of your WTDocument subtype
definition in customaction
<action name="ownJSPPageTab"  >
<component name="cz.aveng.NewDocTab.DetailTabBuilder" windowType="page" />
<includeFilter name="hideDocValidator"/>
</action>
definition in service.properties
wt.services/svc/default/com.ptc.core.ui.validation.SimpleValidationFilter/hideDocValidator/null/0=cz.aveng.NewDocTab.DocValidator/duplicate
this validator hide the action if the subtype document is not "DOCINTERNALSUBSTRING" internal name ends with this string
validator class
package cz.aveng.NewDocTab;
import com.ptc.core.ui.validation.DefaultSimpleValidationFilter;
import com.ptc.core.ui.validation.UIValidationCriteria;
import com.ptc.core.ui.validation.UIValidationKey;
import com.ptc.core.ui.validation.UIValidationStatus;
import wt.fc.Persistable;
import wt.fc.WTReference;
import wt.type.TypedUtilityServiceHelper;
import wt.util.WTException;
import wt.wvs.WVSLogger;
import java.rmi.RemoteException;
public class DocValidator extends DefaultSimpleValidationFilter
	private static final WVSLogger logger = WVSLogger.getLogger(DocValidator.class, "cz.aveng.DocValidator");
	public DocValidator()
	public UIValidationStatus preValidateAction(UIValidationKey valKey, UIValidationCriteria criteria)
		UIValidationStatus validatioNStatus = UIValidationStatus.ENABLED;
		WTReference contextObject = criteria.getContextObject();
		if (contextObject != null)
			Persistable persistObject = contextObject.getObject();
			String subtypeString = null;
			try
				// get object type
				subtypeString = TypedUtilityServiceHelper.service.getExternalTypeIdentifier(persistObject);
				if (!subtypeString.endsWith("DOCINTERNALSUBSTRING"))
					validatioNStatus = UIValidationStatus.HIDDEN;
			} catch (WTException | RemoteException e)
				e.printStackTrace();
		logger.debug("Exit DocValidator.preValidateAction()  status=" + validatioNStatus);
		return validatioNStatus;
PetrH
5 REPLIES 5
HelesicPetr
(To:Sha11)
Hi @Sha11
You need to define own JSP page and crate action definition in the customAction and customActionModel
definition in customAction
<objecttype name="MYACTIONS">
		</action>
	</objecttype>
Put the action to the customActionModel to show in the document tab menu
third_level_nav_doc
   <model name="third_level_nav_doc" defaultActionName="iterationHistory" defaultActionType="history">
       <submodel name="general"/>
       <submodel name="relatedItems"/>
       <submodel name="changes"/>
       <submodel name="history"/>
       <submodel name="collaboration"/>
       <submodel name="security3rdnav"/>                <!-- Security -->
       <submodel name="configLinks"/>
       <submodel name="thingworxCustomizeMenu"/>
       <submodel name="quality"/>
       <action name="ownJSPPageTab" type="MYACTIONS"/>
   </model>
the builder class
import com.ptc.mvc.components.*;
import org.apache.logging.log4j.Logger;
@ComponentBuilder(value = "cz.aveng.NewDocTab.DetailTabBuilder", type = ComponentBuilderType.CONFIG_AND_DATA)
public class DetailTabBuilder extends AbstractComponentBuilder
	protected static Logger logger = ShowChangesInBOMLogger.GetShowChangesInBOMLogger();
	@Override
	public ComponentConfig buildComponentConfig(ComponentParams componentParams) throws WTException
		MultiComponentConfig multiComp = new MultiComponentConfig();
		//multiComp.addNestedComponent("cz.aveng.AVChangeInBOM.AVFilterBuilder");
		multiComp.addNestedComponent("cz.aveng.NewDocTab.TreeBuilder");
		multiComp.setView("/cz/aveng/NewDocTab/DetailTabBuilder.jsp");
		return multiComp;
	@Override
	public Object buildComponentData(ComponentConfig componentConfig, ComponentParams componentParams) throws Exception
		return null;
NestedComponent is definition of table or attribute panel builder..
PetrH
Sha11
(To:HelesicPetr)
@HelesicPetr  - Thank you for the info, will try to implement by following your steps. Could you let me know if there is any article or link which could provide more information on the implementation that you have mentioned?
HelesicPetr
(To:HelesicPetr)
@Sha11
JSP Example>
<%@ page import="java.util.List" %>
<%@ page import="java.util.ArrayList" %>
<%@ page import="wt.lifecycle.LifeCycleTemplate" %>
<%@ page import="wt.lifecycle.LifeCycleHelper" %>
<%@ page import="java.util.Vector" %>
<%@ page import="wt.lifecycle.State" %>
<%@ page import="wt.fc.Persistable" %>
<%@ page import="com.ptc.netmarkets.model.NmOid" %>
<%@ page import="wt.part.WTPart" %>
<%@ page import="wt.lifecycle.LifeCycleManaged" %>
<%@ taglib uri="http://www.ptc.com/windchill/taglib/jcaMvc" prefix="mvc"%>
<%@ taglib prefix="wrap" uri="http://www.ptc.com/windchill/taglib/wrappers" %>
<%@include file="/netmarkets/jsp/util/begin_comp.jspf"%>
<mvc:tree/>
<%@ include file="/netmarkets/jsp/util/end_comp.jspf"%>
PetrH
HelesicPetr
(To:HelesicPetr)
</action>
validator class
			try
				// get object type
PetrH
